I bought a Funhouse cabinet and boards with no playfield. I'm hoping to find a populated playfield, perhaps damaged or incomplete. If I can't do that, I'll have to buy a bare playfield and hunt down the playfield components piecemeal. But some components are "unobtanium." Unobtanium includes the ball guides, although those can be hand-made as Vid's excellent guide shows. Unobtanium also includes the subway and various scoops and ball-handling components, although some of those are sold online or can be made via vacuum-forming.
But the highest isotope of unobtanium is Rudy himself. The face, hair, mandible, eyes and eyelids can be bought. But the actual metal box doesn’t seem to be sold anyplace except used, and for big money. The internal solenoids are available, and some of the actuators and interconnects, but I don't know if you could kit up everything. And having repaired a Roadshow before, I don't even want to try.
In order to reduce my overall cost/complexity, I'm thinking about scratch-building Rudy, but with the eyes and eyelids driven by servos instead of solenoids. (Specifically, servos from the radio-controlled car hobby). Rudy's solenoids are clunky and violent, and they drive the eyes and eyelids through a maze of interconnected parts. Most of those parts would go away if you hooked up servos to drive the eyes and eyelids. You'd just need some circuitry to convert the solenoid drive signals into PWM drive signals for the servos, and you'd need to trim the servos correctly to hit the three states for the eyes (center, left, right) and for the eyelids (open, wide open, closed). But that all seems doable since servos are meant to rest at center, and then turn left or right. It's easy to achieve three separate states with a servo. The way Rudy's eyes are controlled (in a stock Funhouse) is actually really similar to the steering rack on a radio-controlled car. And although a servo slews between positions a little more slowly than the SLAM of a solenoid, steering servos are still *really* fast. Almost quicker than the eye. And it could look kinda cool and robotic if Rudy's expressions were servo-driven.
If I fabricated a Rudy-size metal box out of sheet metal, with holes/brackets for servos, and cobbled together the right interconnect circuitry, it seems like I could make an "e-Rudy" for not too much money. It would add two $15 servos, but eliminate 4 solenoids and some of the fussiest mechanics in all of pinball. I'd still have to buy the plastic face and the mandible and the underlying scoop, and I'd have to cut a piece of wood to mount it all up. But that seems way better than paying big money for an aging, disintegrating Rudy (or Red or Ted) and dealing with those filthy, brittle internals.
Can anyone provide precise measurements for the metal box that forms Rudy's head, at page 2-23 of the Funhouse manual?
