Quoted from PhilGreg:Awesome work.
Can you outline your process? Coat of clear before doing anything else, all airbrush or some decals, etc.?
Yes for sure. I will be happy to.
I took all the components of the playfield as you can see on the pictures. Then i took of the Mylar with the freeze spray technique. I found out it is a very gentle way of doing it. Just use a lot of it and do not pull, only a very very gentle pull, and it comes of by it self when it freezes.
All the glue from the Mylar I soaked a little, with a cloth, in benzine, (not sure if that is the right word, maybe it is naptha in english? i am not sure) and I could rub it of very easily with my fingers leaving nothing behind.
Then I cleaned the playfield the best that i could.
There was some places where the wear was very bad, and almost like a hole down in the wood. And also there was a lot os tiny "holes" or marks in the playfield, for example in the area of the Rudy with the umbrella, you can see it in the "before" picture. I do not know how they occur, but I had to do fill it, so I used a two component paste called Chemical Wood (freely translated from danish, but I think it is the name in english as well) and sanded the playfield level afterwards.
Then I was ready to do all the base colors, i mean the big areas, or at least I thought.
It turned out that the original paint, was very fragile, especially where it had not been covered in Mylar.
I used frisket to cover up when painting, but even though the tack is very low on frisket, it still managed to pull of some of the old paint, so I decided to do the things I could without the need to cover up, for example inserts, black lines etc. before giving the playfield a 2K clear coat.
After giving the playfield a nice thick layer of clear I had no problems with paint lifting off. Also I found that it was easier to correct errors on the clear coat, so the next time I will also give my playfield a clear coat before restoring.
So I did all the big areas of colors before turning my attention to the detailed areas.
After I stripped down the playfield I had made a scan of the worn out areas as I knew I was going to use water slide to restore them.
I used PhotoShop (or GIMP) to redraw the graphics. Some of it was totally gone so I had to find pictures online to recreate the graphics.
The great thing about PhotoShop or Gimp, is that it is possible to draw layers on top of the scan, using the scan as a back ground, and then only print the painted layers on to the waterslide.
As you can see on the picture below I started with the scan "1". Then I made the black areas lines "2", and then i filled in the colours "3". In picture "4" you can see what the graphics look like without the black line and only the colours. As you can se they are very blurry, and that is the good thing about painting in layers. Is is only the black colour that takes a lot of time, because I do not have to be very precise with the other colours because the black will cover and make the borders so it appears nice at the end. In picture "5" I have removed the background and it is ready to print on the water slide.
The water slide is very easy to work with. It is a bit expensive, but as always quality and price normally go hand in hand, and that was also the case here. I found some cheap water slide paper from China, but the colors did not seem to attach very well when going through the laser printer, and also they did not bond very well to the playfield.
I got some water slide paper from the UK, from craftyComputerPaper and that was a totally different story. Very nice product easy to work with, great colours and did stick very well to the playfield. And even though the water slide is only 2 MY thick it is very durable and do not crack or rip at all. I was very surprised by that.
Also it is virtually invisible once dried. It is like it liquifies and floats onto the playfield. It is just a great product. It, as all things, has some limitations, but overall a great help in projects like this.
I forgot to mention that i put a layer of clear on before and after applying the water slides, makling a clear coat, waterslide, clear coat sandwich. I do not knowif that is necessary, but my thought was that I might avoid problems of materials not working together and ripping the waterslide. (I do not know if that made any sence to you?)
After applying the waterslides there was just some touch ups to do and then a layer of 2K clear coat, some wet sanding and another layer of 2K clear coat, and know after 6 weeks to harden I will do a final wet sanding and then the final polish to get it nice and shiny. I can not wait to see the final result.
And then I have to put the whole playfield back together, which I also think will be quite a project.
That was more or less how I did it. I might have forgotten something, but I think it is all there.
By the way. I have all the waterslides I made in PhotoShop and I will be happy to share them with any of you if you need to do a funhouse restoration some day. There is no need to do the same work twice.
These are the graphics I have made for this project. I can not guarantee that they are a 100% accurate since some of it are made but looking at pictures, since not all was there on my scans, but I think they will do in most cases.
Just sent me an PM and I can send them in to any of you in better resolution or as PhotoShop files.
And any other questions or comments, just let me know. I will be happy to reply or help.
