I moved to Titusville Pa and my funhouse game won’t turn on. Replaced the power driver board . Checked all connections and they are correct. Every time I run it on the F 114 fuse burns out. Any help would be appreciated
Quoted from michaeldvo:I moved to Titusville Pa and my funhouse game won’t turn on. Replaced the power driver board . Checked all connections and they are correct. Every time I run it on the F 114 fuse burns out. Any help would be appreciated
Disconnect the playfield from the board. If the fuse still blows you know it's the board (likely a bridge rectifier). If that is the case you might as well rebuild the entire HV section ... these things have age against them.
If the fuse doesn't blow then you have something in the lamp matrix going on. Metal grounding out etc.
This page was printed from https://pinside.com/pinball/forum/topic/funhouse-not-working-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
