(Topic ID: 178028)
Funhouse Mystery Head Assembly Part
By provato
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by provato
REQzNTAwRDFEMzBBNTFEREI5NDc6M2YzZTE2ZjcyYzg2NDUwNGJhYmYwNTY1MDRjNWUwYzY6Ojo6OjA= (resized).jpg
#1 4 years ago
Hi and greetings to all pinball lovers!
(This is my first post so please go easy on me )
I recently bought a Funhouse pinball and as always I catalogue all the parts I find according to the parts list .txt file on ipdb.
After "fishing" inside the cabinet I found this little plastic ring that you can see in the images.
At first I couldn't find anywhere to fit this thing into or match it with the parts list txt, but after taking a closer look in the head assembly's parts, I found this on the text file:
A-13734(1) head bracket assy
--01-9674(1) bracket
--02-4454(2) plunger stop
--02-4457(2) shading ring
--02-4459(2) jaw pivot
--02-4460(1) crank pivot
--20-9670(4) standoff 6/32 x 3/16
After looking at marcospecialties for the 02-4457 part, I found the image of the shading ring there bearing a vague resemblance to the plastic ring I found inside the cabinet.
So, here are my questions about this part:
1. Is the part I found the same as the marco's 02-4457?
2. Where are the 02-4457 shading rings located in the head assembly? (I searched my assembly and photos online but I could not spot these parts anywhere in Rudy!)
3. What is the use of this plastic part I found? I couldn't match this part to anything else in the entire parts list text file...
#2 4 years ago
It might be the centering bushing for the plunger. If you don't have installed, the eyes won't work right.
#3 4 years ago
Maybe you mean the centering flange for the eyes which is part 03-8486? (it's between the coil bracket and the coil of the "A-14030" main lid plunger)
I already have this part, it has a wider hole and is symmetrical, unlike the one in my photos.
So I believe we are talking about different parts
#5 4 years ago
Looks like a centering flange to me.
#6 4 years ago
Quoted from stangbat:
I don't think it's the centering flange of the vertical coil. Here are the pictures of the centering flange:
#7 4 years ago
I think that's a bushing for the eyelids. If I remember correctly there is one for each side where it mounts into his face.
#8 4 years ago
Quoted from Dewey68:
The eylids use small nyliners.
#9 4 years ago
I agree with stangbat. This is not a nyliner, I have both nyliners for the eyelids plastic - they are thinner and their circles are cut.
Let me remind you that this part I posted pictures of in the first post, may NOT be a head assembly's part. It's just a guess of mine that this part is 02-4457 shading ring.
So, I'm searching if anyone has a photo of this "shading ring" on the head assembly, OR if anyone knows where the part goes...
#10 4 years ago
I have my rudy head apart right now and i just looked through it all and it doesn't have that piece. Probably from something else or just garbage left by a old operator, might have even been a part of a hack and not even from funhouse.
Marco shading ring looks nothing like the part you have. Marco part has a single sized bore down the center, the part you has has a two size bore starting with a larger inside diameter then stepping down to a smaller one.
#11 4 years ago
Thank you Mitch that helped a lot, because I also believe now that my part is probably irrelevant to genuine funhouse parts.
But still, one mystery remains about the "shading ring" that you posted the photo from marco. Does this part really exist in the head bracket from factory, and if so, where does it go?
