First, confirm that ALL EIGHT of the switches shown in the switch matrix for column 7 are non-functioning. IF ANY ONE of them ARE working, then you have a simple playfield wiring break. Under the playfield, you likely will find a GREEN-VIOLET wire that daisy-chains from switch to switch that has become broken or pulled. It happens for various reasons, like raising or lowering the playfield. If NONE of them are working, then....
Power off machine and unplug.
The next step I would try is use an OHMMETER to verify the conductivity between the MPU connectors for column 7 (green violet on pin 7 of either of the connectors, J206 or J207) and each of the switches in that column. Start with one probe on the BOARD on the driver chip, Pin 12, and use the other probe to confirm it has connectivity to the J206/J207 pin 7 on each. If you confirm the driver chip to J206/207 is solid, then keep your probe on the connector Pin 7 and from there touch ANY switch below the playfield (identified in the row of switches matrix). Refre to the schematic listed on IPDB and the Switch Matrix. You will see that ULN driver pin 12 feeds J206 and J207 (which are on top of each other on the board) but focus on J206 as it feed the playfield. (Each of those connectors has a green-violet wire on pin 7 of the J206/207). Follow that one from the ULN pin 12 on the chip thru the connector to the switches. This feels like a broken wire or similar. It's possible the ULN driver chip on the MPU is failed, but less likely.
