(Topic ID: 96623)
Funhouse Inside Cabinet Wall Repair
By scampcamp
5 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by joe2012
#1 5 years ago
I've changed my mind about putting in blades/mirrors to cover the damage on my inner Funhouse walls... and they would look GREAT but... the pf is just too tight up against the walls not to cause scratching etc.
What would you use to fill in the deep scratches that are into the wood walls? And
. which paint... brand & color... non gloss? I used Krylon true blue for the head but thought it may be too glossy for the inside.
Thanks for any info.
#3 5 years ago
For non-structural repair any decent wood putty will do fine. I like MH Ready Patch.
Can't help you on the paint other than suggesting you could put some flat clear over the blue or rough it up with some sandpaper to remove some of the gloss.
Someone sells a blue paint for Funhouse, but it's for the cabinet and probably also too glossy.
#4 5 years ago
Yea, I'd use a wood filler or bondo. Sand it smooth, mask tape off and paint. If it's too glossy give it a coat of flat or satin clear. It will be a big improvement ether way. In the end, as long as your happy with it, that's all that really matters.
#5 5 years ago
Ok.... That's great info. Thanks
#6 5 years ago
bend that ball gate back down away from the cab wall. it looks like the wire form in it is scratching the wall. joe
PinSound
$ 999.00
