Hi, does anyone have a hi-res scan or artwork prepared for the inserts on Funhouse. The main inserts I am looking for are the triangle ones at the bottom of the playfield (5-Gangways & Lite Extra Ball), but would welcome any and all.
Thanks,
Carey
Thanks,
Carey
I realize this thread is from 10 years ago, just wondering if anyone still has scans of the funhouse inserts. I know the mylar decals are available but I wanted to try waterslide decals. Looking for scans so that I can laser print them on waterslide decal paper.
Thanks,
Paul
Quoted from Pjake:I realize this thread is from 10 years ago, just wondering if anyone still has scans of the funhouse inserts. I know the mylar decals are available but I wanted to try waterslide decals. Looking for scans so that I can laser print them on waterslide decal paper.
Thanks,
Paul
here you go….
Many thanks ralphwiggum for posting this. I converted files to pdf to print to decal transfer paper which works fine except for STEPS inserts. How do you print decals with white lettering?
Quoted from John1963:Many thanks ralphwiggum for posting this. I converted files to pdf to print to decal transfer paper which works fine except for STEPS inserts. How do you print decals with white lettering?
There are only a few printers that can print white and they are expensive. For white I would get white vinyl and cut it with a vinyl cutter for accuracy, then place the water slide on top of that.
Ideally, I would use the vinyl cutter to make a stencil, and then airbrush the white layer on.
Quoted from ralphwiggum:There are only a few printers that can print white and they are expensive. For white I would get white vinyl and cut it with a vinyl cutter for accuracy, then place the water slide on top of that.
Thank you!
This page was printed from https://pinside.com/pinball/forum/topic/funhouse-insert-scans and we tried optimising it for printing. Some page elements may have been deliberately hidden.
