Hey guys and gals. Thanks for taking the time to read this. I was contacted by a friend who has a moving company. He just got done moving a Funhouse machine for a client. The client told him that it has issues and was looking for someone to fix it. My friend gave them my info and they reached out to me. Let me start by saying that I've never worked on or even played Funhouse. Just never had the opportunity but I am familiar with the machine. I also don't have quick access to the machine. It's on the completely other side of town from me.
I went over and took a look.
The first thing I noticed was that roughly 90% of the lights were out. Those all turned out to just be bad/burned out bulbs. I fixed/replaced all those and then went on to the next issue.
The owner told me that it used to be on free play but after they changed the batteries out, it wasn't on free play anymore. "That's easy," I told them. I opened the coin door and pressed the menu switch....nothing. So much for it being easy. I metered the switch and it was shorted closed. I shot it down to a problem with the board that has the batteries on it. Someone had done the mod where you remove the battery holder and attach wires so the batteries won't corrode the board...but it was too late. The board had some pretty good corrosion damage. I remove it, cleaned it up and in the process, found a shorted diode (D14) and some corrosion under one of the connectors that was shorting pins 3 and 4 (3 was the input for the Menu switch and 4 was a ground). So after replacing the diode and removing the corrosion that was causing the short, the Menu switch worked just fine and I was able to get the machine setup the way the owner had it before.
Now it was time to test everything else out.
Problem #1 - Rudy's eyes don't close all the way. They open and close, but when they are supposed to close all the way at midnight, they never go all the way closed.
Problem #2 - The left flipper bumper doesn't work. The switches have continuity when manually activated, but the machine doesn't register them. There are no broken or cut wires that I can see/find. The diodes on the switches test good.
Problem #3 - The two left drain switches don't work. The switches have continuity when manually activated, but the machine doesn't register them. There are no broken or cut wires that I can see/find. The diodes on the switches test good.
Problem #4 - The right flipper sticks sometimes like the solenoid is staying energized.
The rest of the machine is fully operational. It's playable now, but it has the 4 aforementioned issues. The owner would really like to get these issues resolved as would I. If anyone can offer any help, or knows what to do from running into these issues before, your help would be immensely appreciated. Many thanks.
-Mike
