(Topic ID: 267496)
Funhouse flippers
By WackyBrakke
66 days ago
  • 16 posts
  • 5 Pinsiders participating
  • Latest reply 65 days ago by mollyspub
#1 66 days ago
So I am rebuilding a funhouse. Currently rebuilding the flippers. This is the oldest game I have ever worked on, so first time I’ve run into the capacitor attached to the the leaf switch. I understand this is to reduce sparking. Has anyone ever upgraded the flippers to the WPC style that doesn’t need the capacitor? Is that even possible? Can you add a flip tropics board? Any other options? Thx
742C5DF4-3290-489D-AFBB-53582D658266 (resized).jpeg95235481-684F-4B41-B594-E61E36D97062 (resized).jpeg
#2 66 days ago
I’ve added WPC mechs to my games all the way back to firepower. All I’ve had to do is get this setup and make sure the coil and eos is right.
https://www.pinballlife.com/full-flipper-assembly-for-williamsbally-machines-from-021992-to-101998.html
#3 66 days ago
Quoted from WackyBrakke:
So I am rebuilding a funhouse. Currently rebuilding the flippers. This is the oldest game I have ever worked on, so first time I’ve run into the capacitor attached to the the leaf switch. I understand this is to reduce sparking. Has anyone ever upgraded the flippers to the WPC style that doesn’t need the capacitor? Is that even possible? Can you add a flip tropics board? Any other options? Thx[quoted image][quoted image]
https://pinside.com/pinball/forum/topic/another-funhouse-playfield-swap-3/page/3#post-5619810
#4 66 days ago
You can upgrade the mech to 'fliptronics' style with extension springs, but that won't remove the need for a high voltage eos and the capacitor. Not really feasible to add a fliptronics board
#5 65 days ago
Quoted from chuckwurt:
What eos and coil stop would be needed?
#6 65 days ago
You would need the normally closed EOS here. It doesn't mention whether that also includes the capacitor or not..
Coil and coil stop should match the diagram in your manual, same as with the current mech
#7 65 days ago
Quoted from mollyspub:
The coil stop that comes with the mech if you’re replacing everything.
Make sure the eos is normally closed for this game and that the coil is proper per the manual. These are all options on pinball life to make the mech proper for your game.
#8 65 days ago
Sounds like my best bet is to rebuild to factory specifications and include the capacitor.
#9 65 days ago
the only other real difference with the fliptronic style mech is the extension spring. It's pretty easy to convert your existing mechs to use it too.
#10 65 days ago
Quoted from zacaj:
Now I'm getting confused ... I can just convert the spring and it's now the same? No need to buy the pinball life kit?
#11 65 days ago
No need to buy the kit if you have everything else. The older the game you’re converting, the more parts that will be different and it would make more sense to get the full assembly.
#12 65 days ago
Funhouse is the start of WPC so the mech is almost the same outside of the pawl and spring.
#13 65 days ago
The only difference between early 90s style mechs like funhouse has and the later style is that early use a conical compression spring and the later style uses an extension spring. The extension spring requires extra bits to mount it to, but you already seem to have those in your pic (the plate sticking out of the crank, and the holes on the EOS mounting bracket).
The other differences between the older and newer units are that they use a normally open EOS (without capacitor) and a taller coil stop, but you need the normally closed EOS and capacitor to work with funhouse since it doesn't have a fliptronics board, and you'd want to keep the same coil stop so that the flipper still acts the same as before
#14 65 days ago
It's the factory flipper set up. Do I need the kit ? Will I need a capacitor or can I just transfer over my old one? Thanks to all for the help !
#15 65 days ago
Are you doing funhouse too? If your mech looks like the one pictured by the op above, all you need to do is replace the spring. And yes on capacitor. If the old one works, use it.
#16 65 days ago
Rudy and I thank you !
$ 54.99
