I'm fighting some crazy controlled lights on my Funhouse. Almost every individual lamp is causing another one or two to turn on.
So far I've tried replacing every single transistor. When that didn't work, I swalled out the whole driver board but that didn't fix it. I have also swapped my LEDs for incandescent and replaced probably 25 lamp diodes. I'm not seeing any shorts or anything noticeable.
I started going through the Single Lamp Test and recording my findings on the first 20 or so lamps. I'll upload those and what you will see is the Green highlighted lamp is the only one that should be on. The red lamp is what is lighting when it shouldn't light.
Screenshot_20201110-153245_pintrix (resized).jpgScreenshot_20201110-153309_pintrix (resized).jpgScreenshot_20201110-153311_pintrix (resized).jpgScreenshot_20201110-153349_pintrix (resized).jpgScreenshot_20201110-153626_pintrix (resized).jpgScreenshot_20201110-153651_pintrix (resized).jpgScreenshot_20201110-153720_pintrix (resized).jpgScreenshot_20201110-153750_pintrix (resized).jpgScreenshot_20201110-153818_pintrix (resized).jpgScreenshot_20201110-153850_pintrix (resized).jpgScreenshot_20201110-153909_pintrix (resized).jpg
