I recently purchased a "shopped" funhouse. For the most part play itself is fine there are 2 switch issues (ramp and trap door that need addressing I say that just for general info)
But when I open the coin door the screen kept cycling through as if buttons were being pressed. it would change slightly depending on how far the door was open, but it just keep beeping. I checked to see no buttons are stuck and they are all clear, no loose wires either.it wouldn't let stay on any tests or menu item..
I unplugged the pin cable that goes from the door to the board, wiped it with isopropyl and plugged in.
at this point the volume buttons are the only ones that work, there is a beep from the esc button and it says free play but thats it the test button does nothing no noise when pressed.
and during the game the screen will say open coin door to use buttons while play continues. Does this sound like it needs a new coin door mech?
its on warranty for 30 days so I want to get it fixed while its covered
