(Topic ID: 152201)
Fun House Restoration
By Jonjon74
  • 72 posts
  • 18 Pinsiders participating
  • Latest reply 3 years ago by Jonjon74
  • Topic is favorited by 7 Pinsiders
There have been 66 images uploaded to this topic. (View topic image gallery).
There are 72 posts in this topic. You are on page 1 of 2.
#1 3 years ago
I picked up (2) Fun House machines in pretty bad shape. They were stored in a warehouse for a number of years. One is in much better shape then the other so my plan is to get 1 fully functional and work on the other as time permits. I'm thinking once I get the second working the I will sell/trade the other as a project machine.
#2 3 years ago
Playfields:
#3 3 years ago
I decided to start pulling the mylar and it's looking pretty nice.
#4 3 years ago
I am glad to see that you have decided to restore and bring those two games back to life. Congratulations on your decision!
#5 3 years ago
Having some issues with the electronics. After plugging in both machines the sound boards blew on both. Exact same place.
I ended up calling Clive @ Coin Op Caldron and he said it's pretty normal for those capacitors to blow after long term storage.
I went ahead and replaced the ones and the board is working now.
I decided to send my other sound board, Both CPU boards and one power board.
#6 3 years ago
Cabinet bottom.
One cabinet bottom completely fell and was hanging by the transformer and the other is sagging badly. I made a trip to Lowe's and had them cut me 2 pieces of MDF. Will cut new holes out this week.
#7 3 years ago
Transformer cleanup.
#8 3 years ago
Quoted from Jonjon74:
Hi, what technique did you use to pull up the mylar?
#9 3 years ago
Quoted from sulli10:
Freeze Spray.
#10 3 years ago
any paint come up off the playfield? I have a whirl Wind I am thinking on pulling the mylar
#11 3 years ago
any paint come up off the playfield? I have a whirl Wind I am thinking on pulling the mylar</blockquote
None at all. Worked really well for me.
#12 3 years ago
Freeze spray is the way to go. Did my playfield as well. The blue color is Createx W013 Wicked Lagoon Blue as an exact match on the large blue area's. In the netherlands i order it at: http://www.airbrush-services-almere.nl/shopasa/contents/nl/d170_02.html
For more information and pics of my FH playfield visit: http://www.flipperforum.be/viewtopic.php?f=12&t=5288
Good luck man!
#13 3 years ago
Use the freeze spray method. I used a blowdryer on my F14-tomcat and pulled a lot of paint of the inserts winding me up with replacing all the insert decals. Used freeze on my BTTF, FH and even on my Fire (which has a tendency of being very difficult) and almost no lift. Be careful, be patient and be willing to invest. I usually use 2,5 can of 400ml freeze 75 which costs 19 euros (in NL) per can. So removing mylar usually costs me around 50 euros.
If you want some pics, check my site (in Dutch however): http://www.flippergast.nl
#14 3 years ago
Update: All mylar is off and I'm having a hard time getting the glue off, Tried all the tricks and the only thing that is working is goo gone and scrubbing. But it's cleaning up!
#15 3 years ago
When you take the mylar off you should remove the glue right after or it becomes concrete. Try using ronsonsol lighter fluid I have really good luck with that. Put a piece or 2 of paper towel down and soak it and let it stay for 10 or so minutes and then work the glue. If still very difficult let it soak for longer not letting the paper towel dry.
#16 3 years ago
What exactly do you guys and gals use for freeze spray? Is it canned air used upside down?
#17 3 years ago
Quoted from fiberdude120:
Yes canned air upside down and don't be afraid to put a lot on. Wait till it ices over and peel away.
#18 3 years ago
Before/after
Well, this is the best I can get the playfield. Now onto cleaning parts.
#19 3 years ago
Progress
#20 3 years ago
Aren't you going to do touchups and protect your playfield??
#21 3 years ago
Quoted from HarrieD:
I've done some minor touch up on the bare wood areas. Not really comfortable on anything more.
I'm really looking for a players machine when done.
#22 3 years ago
Rudy Rudy Rudy
#23 3 years ago
Great job Jon! Appreciate the text updates when you get time.
#24 3 years ago
If you don't protect your playfield the artwork is going to come off and all of your work will be obsolete. Pity.
#25 3 years ago
From what I've been reading waxing works great.
#26 3 years ago
New bottom cut and installed.
#27 3 years ago
Legs. before/after.
Hard to see on the after pic, but they came out really well.
#28 3 years ago
With the way you are going it looks like a full restoration. Why not go all the way. Those paint touch ups will ware out quicker than you think and then you will be back to sqaure one.
#29 3 years ago
Quoted from flashinstinct:
I completely agree. This is, I suppose, an underhanded compliment, but I don't mean it to be one: You did such a beautiful job replacing that bottom, that it's a shame to leave any part of the machine looking like shit. I'm with Flash on this one...you probably have the skills to make this a collector quality machine. And you should. (But you probably won't, and that's your prerogative!)
#30 3 years ago
Thanks, I guess, lol. I do have set of skills, but nothing close to what u would take to get the playfield in good shape. I can't mix colors to match, Making stenciles, paint fine curves, circles. I've looked at the guides and its pushing my conferment zone.
I also checked with repair venders and a new play field is cheaper but still outside my budget.
Do y'all have any reasonable solutions?
#31 3 years ago
Sell the playfields you have now and other parts you have changed that are still usuable and buy new playfields. Save up for the difference.
#32 3 years ago
Dammit! I was just gonna say that...
#33 3 years ago
2 questions:
1. Does the playfield look at bad?
2. Whats this playfield worth?
#34 3 years ago
1. Kinda. You've got some planking, it looks like, some chewed up inserts, and some discoloration.
2. Not much. Not many people would buy that to even restore because Marco makes reproductions, which kills the restored PF market in the same way MMr killed the value of MM.
Here's what's frustrating for a guy like me: You've got beautiful new white rubbers and nice looking plastics sitting on top of a playfield that's way past its prime. Even your ball trough looks immaculate. You've really done a wonderful job. Sell the parts from the other game, collect $700, and get yourself a new playfield. You can thank yourself (and me) later when you've got a wonderful machine. Of course, you'll need some new cabinet decals as well, but you're still coming in under $1000 to really make the game pop.
Again, I realize that doing this might not be in your wheel house, but the job you did on the bottom of the cab tells me otherwise.
#35 3 years ago
Do you think it would be better to sell the second funhouse as a project machine or part it out? How much could I get for either?
#36 3 years ago
That or grab the best parts from the second one put it on this restored one and then sell the other one as a project. You would end up with an amazing game and still have money left in your pocket. Not sur eon pricepoint
#37 3 years ago
I kinda leading in that direction. Anyone have any ideas on what the second project machine would go for?
#38 3 years ago
Wouldn't be surprised if you got over 1k for a project Funhouse with parts missing.
#39 3 years ago
Saw a really rough Funhouse at an auction a month ago that went for $1800. GI only.
#40 3 years ago
The price of a project machine IMO, depends a lot on local demand. If it were local to me (200 miles or less), I'd pay around $1k for it, but it is one of my dream machines.
For me, I don't like buying projects I can't personally inspect, and get an idea what I am getting into.
#41 3 years ago
New top back.
#42 3 years ago
Fresh paint.
#43 3 years ago
Looks good
#44 3 years ago
Question: I know you're probably using a circular saw to cut the small holes in the back box back panel and vent holes on the cabinet bottom. But what did you use to cut the big speaker hole? Is there a circular saw that big?
#45 3 years ago
Not sure how the OP did it but using a circle cutter on a router is probably the easiest way to get a nice round circle. Router pivots around a hole drilled at the center of your proposed cutout. You can even make one yourself out of a piece of good quality ply.
I used one like this. http://www.parts-express.com/jasper-circle-jig-model-200--365-250?utm_source=google&utm_medium=cpc&utm_campaign=pla
#46 3 years ago
I used a hole saw for the smaller ones and a jig saw for the larger hole. I made a makeshift compass.
Like this:
http://www.ronhazelton.com/tips/how_to_make_a_compass_to_draw_large_circles
#47 3 years ago
Quoted from beelzeboob:
Question: I know you're probably using a circular saw to cut the small holes in the back box back panel and vent holes on the cabinet bottom....
That would take one helluva carpenter
#48 3 years ago
Quoted from gutz:
Huh? How would you do it? I'm confused...
#49 3 years ago
He is referring to your comment about using a circular saw to cut holes.
See attached pic of circular saw.
#50 3 years ago
Blackbox sanded and started applying wood filler. I gotta say this plastic wood filler is pretty awesome.
$ 22.50
$ 259.95
Pin Stadium Pinball LEDs
