(Topic ID: 163661)
Full Throttle Issue...Video Link
By Russell
2 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Jgaltr56
#1 2 years ago
I just got a Full Throttle and set it up. Everything seems to work fine, except the auto-launch is behaving oddly. Upon starting a new game, it doesn't allow the left flipper rev-the-engine skill shot. Rather, it just auto-launches. Occasionally, it works normally. Not sure what's going on. I did a switch check, and everything seems to be behaving normally. I thought maybe the launch button switch was activating abnormally, but this does not seem to be the case. I have software version 1.3. Is this the latest? Other thoughts of next steps? Check out the link below. (I'm not touching the machine after I hit start.)
#2 2 years ago
Post it in one of the FullTh threads...probably get more response
#3 2 years ago
I'm guessing the switch under the ball when it sets in the shooter lane is our of adjustment. Be sure to check it with a ball, & not your finger.
#4 2 years ago
You have the timed plunger setting to on. Turn it off and it won't auto plunge on start. It's under Adjustments > Full Throttle > Adjustment 1.
#5 2 years ago
Quoted from Wickerman2:
You are correct but technically this is the right way to do it so others can find the solution more easily in the future using the built in filters.
#6 2 years ago
Timed plunger is set to 'Off', and I did a factory reset. Still doing this intermittently. Can anyone confirm that 1.3 is the most recent code?
#7 2 years ago
1.3 is the latest version.
#8 2 years ago
Quoted from Russell:
ยป YouTube video
Do you have a shaker motor connected to the powerboard and it is turned on from within the game menu?
#9 2 years ago
Hmm strange. Maybe try putting it into switch test and knock it around a bit to see if you get a switch to trigger.
$ 50.00
$ 399.95
Gweem's Mods
5,250 (Firm)
Fruitland Park, FL
$ 209.99
$ 109.99
