I've have some issues with my FT switch matrix. Basically when the Test Report shows up I get the following....
GND Short Row 4
GND Short Row 6
GND Short Row 7
GND Short Row 8
Reading through the forums I tried some of the suggestions. If I unplug J212, J206, and J209 all the stuck rows in the Switch Edge test go away.
If I take a short wire and connect J206 Pin 1 to J209 Pin 1 I see all of Row 1 showing connection,
If I connect J206 Pin 1 to J209 Pin 2 I get all of Row 2 showing connections.
I'm not sure if I should be seeing individual switches actuated or entire rows.
What other suggestions would you have me try?
Thanks in advance!
