I posted this in the marketplace, but I am not sure if it posted, so this is going here.
If you've looked for Flintstones Aprons, you'd know that currently they are only available out of Australia for somewhere between $250-$300 US shipped, and then you have to wait on it. That's a lot of coin to drop on an apron, so I've got a used one available in case it's better than one of the ones you have.
The mounting points are cracked and broken on the right hand side. Like most plastic ramps with the same issue, this can be remedied with large washers to secure the apron in place. Because the lower right mounting point also is supposed to have a bit of a stand off molded into the mounting point, you will need to use something as a spacer to get it level with the left hand side. I found that while large washers aren't exactly the most attractive solution, they work just fine.
This is located in the Houston Texas area, and I prefer to limit shipping to the US. I can't get Pinside photo upload to work right now so PM me for pictures and any questions. Again, I am considering offers.
