(Topic ID: 115549)
FS: used CPR fathom playfield 2004 halifax 650$ + shipping
By Redketchup
9 years ago
#1 9 years ago
Hi
I just remove a 2004 cpr playfield from my game to put a 2014 new one. The playfield have been in my game for 4 years. It's not perfect, but real close. I found a topic that explain all the difference between the 2004 and the 2009 playfield
https://pinside.com/pinball/forum/topic/fathom-playfield-by-cpr-differences
All the blue insert got the pinball pal correction kit
http://www.pinballpal.com/inserts/index.php
And the big advantage is all the mecanism as been installed so, all the hole are there and at the right place, so the swap shoulb be lot esier. The only assembly i had to chim is the drop target (6 bank and 1-2-3 bank).
The playfield got a couple of automotive clearcoat when i got it.
There is one place where the new clear seperated with the old one... See pics
There is a dropbox links for the pics:
https://db.tt/PHPwkpz0
If you want specific pics, just ask me and i will take it.
I want 650$ US + shipping (I'm in canada, so expect to pay a little more for the shipping) I will have a CPR box for it.
If you're not in a rush, i will be at allentown all the weekend, can bring it for free, but need to pay in full to close the transaction.
#3 9 years ago
Bump
open to offer...
#4 9 years ago
Playfield sold, pending payment
#7 9 years ago
Will be my first playfield swap (someday). Figure the already drilled/used holes will make it a bit easier on me.
Thanks again, Red.
#8 9 years ago
No problem
Should be a lot easier, because with a new playfield, you have to check all the assembly to be sure it's fit and work correctly and pre-drill all the hole.
When i did my second Fathom swap, I change all the insert socket for 44/47. I keep the 555 only for the GI. Can i suggest you to do the same, make a big difference with new socket and ground braid!
Good luck with your swap!
playfield swap1.jpgplayfield swap1.jpg playfield swap2.jpgplayfield swap2.jpg
#9 9 years ago
Received it just a little while ago. As described and very, very nice. Also, he packed the thing superbly (box, wood sides, staples, inner cardboard, bubble wrap, etc.) so it was more than safe and sound for the trip south. Awesome! Thanks again, Red.
#10 9 years ago
Cool!
Happy it land safe!
Happy swap!
#11 9 years ago
Quoted from Redketchup:
I also highly recommend replacing the 555 sockets with 44/47. I also upgraded all the lighting braids to 1/8" flat braid..
#12 9 years ago
Quoted from Freeplay40:
Yeah that's what I keep hearing. I'm sure I'll have plenty of questions once I finally get around to it. Daunting task, or so it seems....
#13 9 years ago
seem worse then it is in reallity... take your time, take a lot of pics, label everything and seperatly and you should be fine!
#14 9 years ago
1/8" GI braid is awesome.
1) looks better
2) turns corners better
3) if you need to pry up a staple with a sharp tool, you won't SEVER the line, since there are more fibers
4) conducts more
-mof
#15 9 years ago
What a stunning game. I have never payed attention to that title until now. Wow. What system is that?
#16 9 years ago
Quoted from futurepinhead:
Bally MPU AS-2518-35
-mof
#17 9 years ago
Quoted from parkway:
I didn't actually buy new sockets. I had a couple old playfields with sockets in pretty good shape. A day or so in the tumbler and they cone out beautiful. I then soldered all the bases. Turned out great. Fathom was a pretty straight forward swap. Far easier than say High Speed!
#18 9 years ago
With Fathom / old Ballys - is there any workaround OTHER than to solder every single lamp to the GI braid?
-mof
#19 9 years ago
Quoted from mof:
-mof
You're going to have to solder one way or another. Either directly to the lamp base or to a wire terminal to put under the screw.
This page was printed from https://pinside.com/pinball/forum/topic/fs-used-cpr-fathom-playfield-2004-halifax and we tried optimising it for printing. Some page elements may have been deliberately hidden.
