No longer available.
I have a used Bally 122-125 transformer and the attached corresponding AS-2877-1 board. It had two badly burned header pins at connection J3 pins 1 & 2, which are missing and came off when the J3 female housing was removed. At a minimum it will need to have these two pins replaced.
The J1 and J2 header pin sets appear to be in good condition, and at least one of the bridge rectifiers has been replaced at some point.
I have not tested either the board or the transformer brick itself, but I believe that everything else is in order. Sold as is and untested.
Includes the screws that go through the bridge rectifiers (3) and that small plate (incl.), that secure it to the inside head.
$90 plus shipping or pick up at TPF.
