I finally cleaned out my severely cluttered work area so I could start some winter projects and discovered I had a few sets of the Tron arcade mod parts left. I ordered these parts a while back using the detailed parts list provided by the mods original creator on the pinhacks.com site. Since you need to buy multiple sets of the plastic parts at a time I bought a set of parts to build my own and then sold the extra parts as a DIY kit. Demand was high for the kits initially and I bought some additional parts sets to keep up but has since diminshed. I decided to go ahead and just build fully assembled mods with my few remaining parts. I had enough parts left to build 4 complete plug and play arcade mods.
For this last build I improved the design a little more by adding additional light barriers as well as light reflectors to help direct the light more where you want it and less where you don't.
The mod comes completely built and tested and ready for use. I use the 1.5" OLED screen with Eli's latest code running on it. It's a simple plug and play install that only takes a few minutes. The wiring harness along with some cable ties and a pictorial install guide are included.
The mods are completed and ready for immediate shipment. Two of the mods have a UV flasher bulb installed and the other two 2 have a white flasher bulb installed. The UV is nice in that it makes the joystick and lower base mounting plate glow more when it flashes. However being UV its not nearly as bright as the white flasher. So its more of a preference if you want the subtle UV glow or the bright white flash when it goes off. You can specify which bulb style you want when you order it. The flasher bulb is easily changed though if you want a different style or color.
Since I'm not planning building any more of these (it takes quite while and is a real pain) I'm including some extra spare parts I no longer need. They include:
Extra set of decals. If you ever need to open the mod up (replace LED, reprogram screen, whatever, you will need to replace the side decals when you put it back together).
Extra LED's (white and UV) in case the originals ever fail.
Extra UV reactive joystick piece.
Extras spinner knobs in alternate colors (mod is built with UV reactive light blue but I'm also including black or deep purple versions in case you want to change the color).
Extra set of the clear acrylic and purple pieces (display cover, top marquee, front panel, purple black light bar).
Extra base mounting pieces in alternate colors. The mod comes built with UV reactive light blue base. I'm also including a deep purple base as a well as the solid black base. You can't see much of the base when its installed but someone might want to try the other colors.
Cost is $200 shipped via priority mail (within US). Other countries would be a little more depending on location to cover the higher shipping rates. Mods are completed and ready to go so they can ship immediately. Send me a personal message for paypal info if interested. I know a lot of Tron owners have these already so if I don't sell them all here, off to ebay they go.
Attached are some pics of it installed with and without the flash as well as a pic of all the stuff I'm including with mod.
