Selling my ST:TNG. It's a nicer example of the game, not perfect, but it has a shaker motor, full LEDs and Klingon and Romulan ship mods. Damage spots that I am aware of are some Neutral Zone wear (cliffyable) and the front part of the cabinet under the coin door where it delaminated in one spot and was glued back. Other than the Neutral Zone, the playfield is near perfect as I can tell. The cabinet is also very nice and unfaded. There are no errors, no burned connector or acid damaged boards and the DMD works fine. The pictures really show better than I can explain, so here you go:
http://s270.photobucket.com/albums/jj87/trolling/STTNG/
Asking $4000. I will be traveling to Wisconsin around the 15th of April, so if you are along my route and want to pay me a $200 deposit I can hold it until then. I take the tollway through Penn, Northern Ohio and Indiana. You'll have to be somewhat flexible on the meeting time because I don't want to plan my trip around meeting someone and I could be traveling through your area at 2 AM or something. Otherwise I'll be in Wisconsin up around Appleton for a couple of weeks.
Thanks for looking!
