Archived ad
Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
Other items - for sale
FS: Sega Frankenstein (Middle TN)
Added: 2021-03-12 23:00:00 UTC
• Re-listed: 2 times (June 22nd, 2021)
• Ended: August 4th, 2021
Price
$ 2,800 (Firm)
Price is firm
For sale is a 1995 Sega Frankenstein. The game is fully playable. It is currently on location at a laundromat in Lebanon, TN and is available for play testing. Some insert lamps will need to be replaced. The CPU board has NVRAM installed, batteries removed, and no battery acid damage.
Cabinet is in good condition, with no fade. There is no major damage to the cabinet, including no water damage. This machine has been operated and stored in a dry warehouse since it was manufactured. There is no smoke smell and no nicotine stains as it has not been operated in a bar recently.
The playfield is in overall good condition. It has Titan silicone rings. The game has been kept clean. There are no lifting inserts and only minor wear in heavy traffic areas. There are no playfield hacks such as wood screws or other such damage. The playfield art remains original with no touch ups. There are LEDs installed in the GI. The forest plastic in the upper left has been glued. The plastic around the creature is also broken.
The machine is 100% playable. The creature head mechanism is working. The sound board has been re-capped and tested. This also has a Dr. Pinball color LCD display installed. The game has an aftermarket X-Pin power supply as well. There is a minor issue where the display can freeze if the game is powered on for long periods of time, as in multiple days. This occurs in a 24/7 run time scenario. Should not be an issue for home use. The issue is most likely the 5v power connector on the display controller board.
This is available for pickup only in Lebanon, TN. You will be responsible for loading up the game. Cash only. This is being sold as-is in current condition. Nothing is guaranteed, no warranty of any kind offered, and I will not be able to assist in any way if you contact me about an issue following purchase. No returns or refunds.
Please PM me if interested or if you have questions. Thanks.
Item photos
Photos not showing? Make sure your ad blocker plugin is not hiding them.
Contact
Note! This is an archived ad. No longer for sale!
Seller insights
These are Crash's market stats.
Listing result
The seller marked this ad as "not sold". The item did not sell through Pinside so there's no listing result.
