Game is pretty nice. Flippers done and some led's added. Hand needs special nut to work properly. It worked perfect before the nut stripped. $1400
Quoted from Rascal_H:Considering it...
Would Roy Clark bring the price down at all? I know you like some older games.
? let me look the game up. Who the F is Roy Clark!?
Quoted from Snowdale:? let me look the game up. Who the F is Roy Clark!?
Here's the actual game.
Roy Clark was on Hee Haw or some shit. But he was really an amazing guitar player.
Quoted from PeteM:Obessive compulsive correction: Mnemonic not "mnumonic"
Yes please, it's starting my ticks again.
What's the deal with striped hex nut? How hard is that to replace? How hard will it be to fix the hand?
Got this from another thread.
It is actually easy to change them out, the X nut you only have to remove the bracket on 1 side behind the matrix 2-3 bolts, remove the two c-clips off the X nut and spin it off, or slide it off if its real bad. You will be able to tell right away if you can wobble the nut on the shaft that its bad, it should be able to spin but not flop/wobble as you spin it off.
The Y nut is pretty much the same but there are c-clips on the bracing rods to remove and the main stainless bracket to get the nut out the same way with 2 c-clips.
be sure to use a tiny (real tiny) bit of lithium grease on the gear/rod when you get it back together.
This will 100% fix you problems
Thanks! Is there a tool to remove and replace c clips easily? Those damn things made replacing a shooter rod quite an adventure!
Back to topic. I will be in Boston a week from this Thursday. I'll try and check out the game if still available.
Quoted from TheFamilyArcade:Thanks! Is there a tool to remove and replace c clips easily? Those damn things made replacing a shooter rod quite an adventure!
I use needle nose pliers.
This page was printed from https://pinside.com/pinball/forum/topic/fs-johnny-mnumonic-in-ma and we tried optimising it for printing. Some page elements may have been deliberately hidden.
