Here is the info on circus : $950
Gameplay: 8 out of 10. The kick out hole on the lower left of the playfield does not work. In the 100 or so games ive played on it it has not landed in there once! Ive also just had an issue with the 3rd player display just locked on (Like it knew it was on the trading block!)
Playfield: 9 out of 10. It has some slight wear near the left kick out hole. It was touched up very very well. You have to look for it to see it.
The cab: 9 out of 10. It has a nick and a scratch here and there. NOTHING that noticeable.
The backglass. 9 out of 10. It has the SLIGHTEST flaking. The reds are in tact. This is probably the nicest circus backglass you will ever find.
Pictures: http://s1162.photobucket.com/albums/q533/The96stang/Circus%20Pinball/
Info on Bad Cats! $950
Gameplay: 8 out of 10. The drop targets on the left are sluggish and the middle wheel is not quite right. I do not think it spins far enough. It does have a BRAND NEW rottendog MPU in it.
Playfield: 9 out of 10. It has some slight wear near on the trash can light in the back left and has 4 or 5 broken plastics. See attached pictures.
The cab: 8 out of 10. It has a minor chipping on the bottom left side, but the reds are bright IMO.
The back glass. 9 out of 10. It has the SLIGHTEST scratch on the top right. Not noticeable when playing. It is NICE.
Pictures: http://s1162.photobucket.com/albums/q533/The96stang/Bad%20Cats/
LAH is a project. It needs a new power supply. The one in it is hacked apart. What that means for the MPU, I do not know. This one is as is and is probably the last one I want to sell. The PF has no wear, but could use a good set of cliffy protectors. If I cannot get 800 out of it, I will not sell it.
Take ALL of them for 2400.
