Game is located in Lutz (North Tampa, Florida).
Playfield, plastics, posts, and targets cleaned, new rubber, new plastics near the flippers. Newly painted legs, new levelers. CPR backglass. Playfield has some wear, see photos. It is a solid playing game with no mechanical issues.
The sound board has a brand new FULL cap kit installed, new .156 header pins AND volume pots. The coin door volume pot was dismantled, cleaned and reassembled. It sounds AWESOME!
All the .156 header pins on all the displays have been reflowed. I replaced the C23 cap on the driver board for reliability. All the .156 header pins on this board were also reflowed. All the driver board .156 connectors were replaced with new trifuricon type.
A new 3xAA battery holder was installed with a blocking diode.
All new instruction cards for the back box were installed.
The lock down mechanism for the lock down bar was removed, soaked in rust and corrosion treatment over night, then painted silver so it won't rust again in a few months.
The shooter was spun polished and installed with a new barrel spring. It was lubed with graphite.
The lock bar for the backglass is missing. All this means is you can't lock the backglass in place with a key. If this is a big deal for someone, I can try and locate one.
I've been through every aspect of this game from top to bottom. As of today, I've put on 257 plays on it in the past two months, and that's BEFORE I shopped out the playfield last week. It's good to go!
Price: $2900
PICS: http://s1215.photobucket.com/user/pinballshark/library/Fathom
Game Play Video:
Thanks for looking!
