I think the problem may be that people are reluctant to putting any money into a board that's damaged.
Truth is, this board is crazy simple....not much to F-Up. Perception is that all boards are incredibly hard to work with.
If I could suggest, why don't you fix the board and sell a **working** repaired board set for $25+
Testing is simple. Continuity tests for your own sanity... then.
The receivers will have a resistance change when exposed to a mag light (put your DMM on the pads).
The senders need a power source. Jumper from the connector to the pad and view each LED with a digital camera.
Just a thought. Or perhaps this post may inspire someone to take a chance on a great priced board set.
GLWS
faz
