Thanks for the Pics.....love to see my stuff on other peoples games.
Few notes;
1. Went by the powder coat guys place and he was covered in green powder....needless to say the red was not ready.
2. I dropped off enough to do 10 sets beyond those that have already placed "orders" or asked for a set to be held.
Quick learning curve note.
The testing:
The bolts are made to flash on and off or pulse, I stress test each bolt for 2min @ 16volts. This is repeated twice- once before and once after final assembly. Sixteen volts direct is something that will never happen during game play unless a flasher driver stuck on during a failure. My bolts were built to operate from 10v-30v.
As someone has posted above, I have had a few of the pcb boards drop out 3 leds after being installed. Of the ones I have had swapped out for this issue, everyone of them can be fixed by reheating the solder on the back at the resistor for the string that dropped out. Each of the small square resistors on the back of the PCB board that are installed "floating" meaning there are no legs to the resistor. The only way I can get a board to fail after stress testing is to bend the white pcb board. Just a note that if you have to adjust the position of the board avoid putting pressure on the white board and put all the pressure on the steel frame.
If anyone has any issues please pm met to let me know.
