I love solving matrix puzzles. So to summurize, The saucer rollover button is located at the intersection of ST3-I0. We are looking for a path that will get us from St3 to I0 through the bottom side drop target.
so lets follow the map for the easiest path. We need a shortcut through a target or switch that it's normal to be stuck closed. Coin switches are often the culprate because they do not have diodes. However a drop target with a bad or shorted diode will do the trick too.
Here is what I came up with, start at St3 pass through the spinner then onto St4 via the top side target.
So my scenario is: If the spinner is spinning and the top side drop target is down and has a bad diode then knocking down the bottom side drop target will give you the saucer rollover button. Not an easy path but possible.
Look for your own path from S3 to I0. Remember to pencil in the slam, tilt, and coin switches as they are part of the matrix too.
