http://www.pinballrescue.net/Decals_Apron_Gottlieb.html
Decals here
Your apron doesn’t look too bad.
Color match and touch up would be less work.
That’s a very decent original. I’m struggling to see any scratches. Some light rust where the ball drains is all I can really detect.
The decals from Pinball Rescue are well produced, but they are essentially giant stickers. They only have the blue and red colors printed on them. The rest of it is transparent, so you have to strip the paint off the old apron, spray it with white paint, redo the webbing, and apply the sticker carefully to avoid bubbles.
Quoted from Slickfam99:How do you go about refinishing the front apron? Mine has several scratches and was wondering what everyone else does to make these look better? I can duplicate the front score card but those scratches!
Tim[quoted image]
Tim,
What scratches are you referring too? Are you referring to the webbing?
Quoted from SteveinTexas:Tim,
Oh, good point. He probably is. My very first game was a King Pin, which had very fine webbing on it. I thought they were scratches, too!
I'll take a closer look at the finish. Maybe I was mistaking the webbing for scratches. I was going to wipe down and put a layer of wax on it to keep the sheen.
Quoted from Slickfam99:I'll take a closer look at the finish. Maybe I was mistaking the webbing for scratches. I was going to wipe down and put a layer of wax on it to keep the sheen.
Wipe very carefully. The ink on the apron has no protection and will come off with just about any solvent, including water. The webbing is a little more robust, but it will also disappear with cleaning that is too aggressive.
You're most definitely mistaking the webbing for scratches. I don't see a single scratch anywhere on that apron.
I clean mine by lightly moistening a rag with Windex and gently wipe. You might try plain water first. That might be enough. Look at the rag to see if any paint is smearing. The red is very susceptible.
I can live with an original with webbing as long as everything else is ok. However, if there's a lot of rust or other paint loss, well, I don't care that much about the webbing. I'm going to refinish the apron. It's right there in your face and what's the sense in doing a full restoration and reusing a rusty old apron?
This page was printed from https://pinside.com/pinball/forum/topic/front-apron-restore and we tried optimising it for printing. Some page elements may have been deliberately hidden.
