Will the Bally radical ramps be available only as a complete set, or the option to buy only the ramps needed.?
Quoted from yellowghost:
Individually, but may consider a reduced set price.
Freeplay40 - I will take a COMET center ramp too! I've needed one for 2 years and can never find one. My is all kinds of busted and rigged up. Please let me know if you have any more available and put me on the list!!
Quoted from Ryguy25:
Others have been asking so I will too.
Can you please confirm if I am on the list for 1 Comet center ramp?
Thanks,
Ryguy
Yup...#25
Hi. I’ll this weekend be finishing Rocky and Bullwinkle whit ramp I got from you [ excellent ramp}. ‘Will post pics. Thank you
I'd definitely like to be on the list for the larger Radical ramp with the funnel. Still hoping that someone will eventually make the decals for that ramp...can't seem to find them anywhere.
Quoted from per3per3:
You can remove the decals from the old ramp no?
On the two ramps I had loaned to me for the first ones, the decals were already peeling off and with a little Goo-Gone they would have removed very easily. Once the old glue is cleaned off, again with Goo-Gone, new adhesive can be applied to the decals with 3M decal transfer tape.
3M 467MP is the right stuff.
Quoted from Freeplay40:
Appreciate the info...I didn't consider this option. So goo gone can be applied to the decal to remove the old adhesive and this doesn't tear or destroy the decal? If so, that is good to know!
I wasn't aware you could without a high risk of damaging them
I've removed several decals with Goo-Gone. I use a very small stiff paint brush and first work up a corner. Then just gentle pulling while I continue to use the brush between the ramp and the decal...basically dissolving the glue as I go.
You can use air-duster to freeze them too. Same as removing mylar.
I bet if somebody sent a decal to pps, Rick would have them produced. I suspect he would be able to sell about 42 of them right off the bat.
Quoted from jaytrem:
That would work. Shipping a bit high, but at least it's an option if a transfer goes bad. Thanks!
I ordered 3, with the exchange rate it was $36.48. Did not think that was bad.
$36.48 USD = $49.19 AUD
1 USD = 1.3486 AUD
I could use a lower left radical ramp but I’m debating if I should just wait for the whole set... hmmm
Quoted from Santis:
Hi. Could you put me it to demo man ramp set. Thank you
Wonder how many DM ramps requested.
I'd be up for a couple complete sets of Demolition Man ramps. I think there is 3 plastic ramps?
Quoted from chad:
4 if you count the cryo claw ramp section and subway.
Quoted from chad:
I have the three donor playfield ramps, but I do not have the Cryoclaw or the Subway. Is there interest in the Cryoclaw and the subway?
Quoted from underlord:
5 if you add the piece for the cars. I've had two DMs and they were cracked on both.
Freeplay. I have a cryoclaw to use as a donor if you need it. And I may a subway. If you do them I want a “Complete set”. Thank you
Yes, I'd definitely like to be able to purchase a complete set. Both the Subway and Cryoclaw ramps suffer from cracks and splits. All the ramps on this game either suffer abuse from the ball or previous owners tightening down screws too firmly on metal support posts. Go hard, go all the way!!
Yes. They’re, what, 26 years old now. Mine are all busted to crap. Brittle af.
The modes look like they are silkscreened on the cyro-claw plastic. You would need to hope somebody can produce a decal.
If they are silk screened on top, would be pretty easy to print to adhesive back vinyl.
Plastic simple degrades over time. That fact is also a downside to NOS as it too has aged.
Absolutely. If you make a complete DM set I’m in. These B/W gems need a lot of love!
Quoted from TZ:
Any progress on the "un-obtanium" left ramp for I500?
Sorry...not in the near future for me. Have you asked Larry at Starship?
