(Topic ID: 150775)
Freeplay40 Ramps
By Freeplay40
  • 4,115 posts
  • 651 Pinsiders participating
  • Latest reply 21 days ago by Bohm
  • Topic is favorited by 375 Pinsiders
There have been 535 images uploaded to this topic. (View topic image gallery).
56 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 4115 posts in this topic. You are on page 66 of 83.
#3251 1 year ago
Quoted from spent85:
I am not sure if this is the right place, but I would love to buy a new subway for my Data East Jurassic Park, and a ramp too if possible, but definitely the subway!
Can you measure the JP Subway ramp end to end?
#3252 1 year ago
Transporter !
I just brought my restoration project home, playfield restoration time now, cabinet and boards finished
Super pumped that I should be done about the time ramps might be finished!!!
Awesome freeplay40!
#3253 1 year ago
So, although the calendar says summer, it's been cool and damp here for the last week and looks like it will continue for a bit. This really slows down the curing of the molds. I have cast 8 different pieces to do the Transporter ramps (3 casts), and the Black belt (actually cast 4 pieces). The Black Belt has a clear cover and I cast three pieces to make a full "pie" so I can get three at a pull. Lastly, but will actually be first produced is the Radical ramp. I can do some work on the molds, but just below the surface you can still see a lot of moisture.
The Radical Ramp is probably 98% ready to use. Just needs a final sanding and a hole or two drilled in it....and yes, it is still curing. The thickness plastic I am going to use for the Radical ramp is .177". Next readily available thickness is .250 and that would be overkill. Everything is metric now, so .177 equates to approx. 4.5 mm.
My supplier does not have any .177 in stock so it will be coming up from Los Angeles....Looks like two weeks before I get it. Mold will certainly be sufficiently cured by then. First formed and finished will be for @dung (donor). Once I have the plastic, I will have his ready in just a day or two.
#3254 1 year ago
Quoted from Freeplay40:
~23 inches from the long end to the other along the outside.
#3255 1 year ago
I'm so excited for demo man ramps!!!
#3256 1 year ago
Errrrrr...... everything I just said was wrong, so going to just remove it and move along.
#3257 1 year ago
Quoted from newovad:
Unfortunately that's just a little too long...another one for the new machine.
#3258 1 year ago
I would buy a JP subway too.
#3259 1 year ago
Quoted from mbott1701:
The JP subway ramp was discussed last year and Mark said it was too large for his current setup. I need a new one too
#3260 1 year ago
It has been mentioned several times in this thread, but I would really love to get a set of new left/center/right ramps for a JOKERZ!. The Upper Playfield is the only part that is easy to obtain. The ones I have are slightly cracked and one is slightly malformed around the flasher hole, but overall they are probably good enough to be used as a mold. I'd be happy to work something out where I send the ramps to you.
#3261 1 year ago
Quoted from ktownhero:
I have and will continue to consider those. Artwork for the upper ramps is not available.
#3262 1 year ago
For those of us that have ramps that just need to be replaced, the art can be transferred easily. It would also be possible to scan and print new ones. I'm just interested in getting the plastic ramp itself, which also seems to be the case for the others who have mentioned JOKERZ! in this thread.
I guess I'll just keep checking in now and again and see where you are with considering these.
#3263 1 year ago
Is anyone making decals for the Radical! Ramp?
#3265 1 year ago
Quoted from Chosen_S:
Not to my knowledge. I pulled mine off and cleaned the adhesive off. Planned on reusing them when the ramps come.
#3266 1 year ago
Quoted from dung:
Do you mind scanning them since you have them off? I’m sure someone will need the files soon . This would help tremendously!
#3267 1 year ago
Also would like to be on the list for Jokerz!
#3268 1 year ago
I already contacted dung to see if he could scan them. Unfortunately, he does not have a scanner.
#3269 1 year ago
Quoted from Mitch:
ME ALSO!!!!!
#3270 1 year ago
Haven't considered that one yet, sorry.
I would love it if you done the y ramp for road kings, these are always yellow and cracked, I reckon you would sell a few.
Cheers
Paul
-1
#3271 1 year ago
Quoted from Fezlar:
Cheers
Paul
Wouldnt the ramp be worth more then the game?
#3272 1 year ago
Somewhat Off topic hope you don’t mind but can anyone help me understand where to buy a ramp flap for Bally Atlantis? Where the ramps for Bally Atlantis ever considered? Thanks I’m advance
071CA317-8FA9-4195-B585-3C768B2387B3 (resized).pngC20FD0D0-B694-4777-B4F2-6D1B7EFBD8A8 (resized).jpeg
#3273 1 year ago
Quoted from djsolzs:
Somewhat Off topic hope you don’t mind but can anyone help me understand where to buy a ramp flap for Bally Atlantis? Where the ramps for Bally Atlantis ever considered? Thanks I’m advance[quoted image][quoted image]
Looks like a complete new lift ramp is needed.
10
#3274 1 year ago
HS owners might be interested in a stoplight replacement that I am working on that should be an alternative to relocating the stock housing. Full credit to Freeplay, this was his idea
More info here:
https://pinside.com/pinball/forum/topic/high-speed-club-dispatch-this-is-504-we-have-a-club-now-over/page/53#post-5082176
#3275 1 year ago
Quoted from RobF:
More info here:
https://pinside.com/pinball/forum/topic/high-speed-club-dispatch-this-is-504-we-have-a-club-now-over/page/53#post-5082176[quoted image]
You can buy the stock housing now at pinball life.... It's no longer unobtanium
#3276 1 year ago
Quoted from lordloss:
That's great, but you are missing the point. Goal here was a more realistically shaped housing.
#3277 1 year ago
Freeplay40: Can you make any ramps for Blackwater 100 or know of anyone with any?
#3278 1 year ago
I doubt I will ever attempt those. Too much artwork.
#3279 1 year ago
I don't know which one would be worse. Blackwater 100, or Zaccaria inner backglasses.
-Hans
#3280 1 year ago
What if you just made generic ones?
#3281 1 year ago
Quoted from DreamTR:
Too big anyway for now.
#3282 1 year ago
If you don't mind me asking, is there a way to make a mold from existing ramps that does not damage the existing ramp? I was wondering if you could coat it with something prior to using bondo or plaster?
#3283 1 year ago
It's hard to avoid some damage. While Bondo is nice when finished, if you try to cast with it, it will damage the original as it gets too hot.
#3284 1 year ago
I have Blackwater 100 tools but it just isn't a viable commercial option unless you want to pay 500-600 for a set.
#3285 1 year ago
Quoted from lrosent345:
Ouch!
#3286 1 year ago
This has probably already been asked Mark but is a silicone mold able to handle the heat? I guess the other question would be is it too flexible for the forming process?
#3287 1 year ago
Honestly, given the amount of vacu-formed plastics on the game, that's a lower estimate than I would have expected.
-Hans
#3288 1 year ago
Quoted from HHaase:
-Hans
My thought too! The problem with Blackwater is it would only probably sell maybe 20 sets.
#3289 1 year ago
Quoted from Mancave:
Sorry, don't know.
#3290 1 year ago
Sorry, don't know.
Is cutting a new ramp flap something you would be willing to do? For a price obviously. I have acsess to the material and a person who can re-rivit it but he doesnt have the tools to cut it.
#3291 1 year ago
Quoted from yellowghost:
Not something I ordinarily do, but yes I can make you one. Can you scan it and then give me a couple measurements....like distance between the holes?
#3292 1 year ago
Just another note on whether silicone could handle the vacuum forming process. In order to get good definition on ramps, the typical shop vacuum set up just isn't strong enough. I use either wood/bondo combinations (custom stuff) or a ceramic. Vacuum strength is measured by how far a vacuum can pull mercury up a tube. The typical shop vacuum can only pull that mercury 6"-8". My set up will pull that mercury 25". That said, it is actually strong enough to occasionally crack a mold....so silicone will probably not withstand the vacuum.
#3293 1 year ago
Almost all of my tools are aluminum or cast aluminum. If I make a tool it is always made of epoxy. Some epoxy works. Some don't. Much depends on how many ramps you can get off a tool. So far the tools I have made have been excellent but I haven't made more than 100 pulls.
#3294 1 year ago
I was wondering if a carbon fiber resin would work or fiber glass resin. Finished product could still be worked.
#3295 1 year ago
I would pay 500-600 for a new set.
#3296 1 year ago
I see work is in progress on Black Belt ramps. Do you have an estimated completion date? Thank you.
#3297 1 year ago
Quoted from jhozeska:
I'm not very good with estimates, but it's pretty close. Hardest part is just getting the mold cast and cured which is done...Just need final finishing. I'll give myself some hedge here and say I should have something to show within 2 weeks. Once the first one is made I will arrange with a local friend to test fit.
#3298 1 year ago
I would pay that in a heart beat!
#3299 1 year ago
You could do a kickstarter. It's basically a presale. If you don't get enough, not big deal.
#3300 1 year ago
Radical Ramp update.... Just received word that the special thickness plastic I need for the Radical ramp is in town. Needs to be cut so won't be able to pick it up until Monday. In the meantime I will do a test pull on the ramp with .150 plastic so I will be ready when I get the plastic. Should be able to start shipping by mid next week.
Trade
Machine - For Trade
Smiley, TX
$ 54.99
Cincinnati, OH
