I'm going to mention the center ramp for Who Dunnit as well.
Quoted from blowback1976:I'm going to mention the center ramp for Who Dunnit as well.
not a vac formed ramp
Quoted from Whysnow:not a vac formed ramp
Yes the original was an injection molded ramp. The chances of this being made again are slim at best. If the original molds could be located the chances might be better, however, if the original molds cannot be found the chances are probably nil....
However.....I have discussed this with a friend locally and we are seriously going to take a stab at creating a vacuum formed replacement for this ramp.
Quoted from Freeplay40:Yes the original was an injection molded ramp. The chances of this being made again are slim at best. If the original molds could be located the chances might be better, however, if the original molds cannot be found the chances are probably nil....
Doh!....and thanks.
Quoted from Ericpinballfan:I have't checked-in a couple weeks. Exciting news about Hurricane center ramp. Just a few weeks from starting that one, pulled all the boards last week. Only sound card is worth saving. I have everything ready to go except that center ramp.
I'm mounting the mold in the machine now. Need to set up the plugs and should be able to form the first test early tomorrow!
Quoted from Freeplay40:I'm mounting the mold in the machine now. Need to set up the plugs and should be able to form the first test early tomorrow!
Sweet!! Your the man!
Amazing ! It is also amazing the excess plastic it takes. Looks like the hard part is cutting the ramp away from leftovers.
Clear is best on this one, no need to color.
Great work!!!!!
The actual forming is the fun easy part for me. The hard parts are making the molds (this one took me over a month to get just right) and the finishing.
Quoted from Freeplay40:The actual forming is the fun easy part for me. The hard parts are making the molds (this one took me over a month to get just right) and the finishing.
Looks like you must have a real knack for it! Fun thread to read. Pinball needs you.
Others have mentioned the crossover ramp in Transporter The Rescue. It is an injection molded ramp. I see this on ebay, which is a whitewater ramp it says. If it can be vacuum formed, I bet you could do a transporter crossover. PM me if you want to check one out
I think alternatives to injection molding are very possible... However they would be certainly different than original. I'm working with a friend right now to see if we can come up with an acceptable version of the Elevator ramp for Who Dunnit. We think we can. Ultimately when I get the new machine running with everything I want on it, I will be able to do vacuum forming with pressure assist. With pressure assist greater detail can be achieved.
Quoted from Ericpinballfan:Amazing ! It is also amazing the excess plastic it takes. Looks like the hard part is cutting the ramp away from leftovers.
Great work!!!!!
This could be formed in a shorter piece of plastic, but when I buy plastic, I buy full sheets cut to a certain dimension. This one happened to be basically 16" x 24" which nets me 12 pieces from a standard sheet.
Hurricane Ramp update....will delay production by a few days
I have seen some subtle differences in ramps, but was very surprised today when I found a significant difference in two Hurricane ramps I now have in my possession. I modeled the new ramp after a ramp that was donated to me by pinster68. Dave Beecher with FAST Pinball has loaned me his Hurricane for test fitting. I removed Dave's ramp today as his was not as damaged as the one I received from pinster68. The one I got from pinster68 has a couple of the mounting tabs broken off and I wanted to get those properly "mapped". I discovered a very significant difference at the drop hole in the upper center of the ramp. Specifically is has to do with the position of the drop hole and its relation to where the ball will actually drop amongst the three pop bumpers.
The difference in the position of the drop hole is about 1/2"... Very significant. So I have two ramps so my odds of getting the right one were 50/50... Bummer...not so lucky.
I've attached a couple photos to demonstrate the difference just as info. I suspect that early in production with the first ramp (pinster86's) is that when the ball dropped through the hole it did not fall amongst the pop bumpers, but rather on the top lower edge of the upper bumper....pretty obvious when I position the two ramps in the game.
So I will be modifying the mold over the next couple days based on Dave's ramp. Nobody said it was going to be easy!
The first ramp is pinster68's and the second ramp is the one from Dave. I put a red line on the photos to show the difference. I think I'm going to widen the area where the drop hole is slightly so that the hole actually fits better.....kind of looks like it is crammed into the space.
Quoted from Freeplay40:Here's another photo of one ramp on top of the other. Pinster68's ramp is on top and the correct one (Dave's) is below...
Dave's was cleary an "upgrade". Basically it was just extended. I'm going to clean up some of the lines around this area. Found a small shortcut to get me closer quicker. I custom cut a piece of my mold material and cemented it in place. Now just need to let it set then clean up the lines. Want to get a new test ramp formed tomorrow morning. I will then cut one out manually to get the fit perfect.
Quoted from TheOnlyest:as long as that "afterthought" goofy plastic was there
Yeah, that would have been the Band-Aid to counter the problem with the earlier ramp already installed....sort of how I view the High Speed ramp cover which I designed out of mine.
Quoted from Freeplay40:Yeah, that would have been the Band-Aid to counter the problem with the earlier ramp already installed....sort of how I view the High Speed ramp cover which I designed out of mine.
Indeed, and the way they mounted that plastic is as half-assed as anything i've ever seen. But I wouldn't trade my early game for a later version, mine has the independently controlled, animated, lighted pop bumpers... My understanding is that the later games had NO lights in the pop bumpers at all!
Quoted from shicketmaster:Has anyone mentioned the subway ramp for data east Star Trek 25?
I think it has been mentioned. I don't know what it looks like off hand. Any chance someone could post a photo?
Quoted from Caoliber01:I'm looking for swords of fury main ball shooter ramp thanks! Someone said you made some.
Sending pm
Quoted from Djude:I'd be interested in a Time Machine Starwarp ...
Time Machine - Starwarp ramp please. All of them are broken..
Quoted from shicketmaster:Not my picture but this is what it looks like
I'll look into that one. I'll see if I can locate a donor locally.
Quoted from Barakawins1:Time Machine - Starwarp ramp please. All of them are broken..
Getting several requests for this one so will look into it as well.
Time machine yes. ..and from the looks of it everyone who owns time machine would want a replacement
i am also in for the Time Machine Ramp
(and actually +3 for the upper right Hook ramp )
Quoted from Hammerhead:Would a BTTF ramp be possible?
Honestly, that one would be pretty far down the road...sorry.
Quoted from Freeplay40:I'll look into that one. I'll see if I can locate a donor locally.
Put me down. for one....
Quoted from Freeplay40:Honestly, that one would be pretty far down the road...sorry.
Took a day off to go up to some property in the mountains to cut down trees and burn stuff. Setting up now to form the corrected Hurricane center ramp. All goes well hope to post a finished form this evening. In addition to the entrance flap which will be installed, the ramp does have three metal pieces riveted to it. Expect options for this ramp will be new metal pieces riveted to the ramp or I will rivet your supplied pieces for free.
Just posted the first photos of a basically finished Hurricane center ramp. Started a thread specific to it.
https://pinside.com/pinball/forum/topic/new-hurricane-center-ramp#post-3202718
I would be in for the Star Trek 25th subway too. Love the blue Space Station one I got from you...
I asked about the subway ramp for STar Trek 25th in passing, but now I'm 100% in as I've got that machine coming tomorrow and unplayable until the ramp issue is solved. Going to try and rig something up in the interim.
Every once in a while I get a bad batch of plastic. My supplier is usually pretty good about making it right. I had one red F-14 to get out so I formed one and finished it out last night. This morning I noticed a small bubble in the plastic and decided not to ship that one. I started off today forming the red again and each time I encountered the same bubbling in different degrees, so I stopped after the third one and contacted my supplier. Will go meet with them on Monday....I do have a couple pieces of red from another batch that is in a larger piece so I will cut it down and get the order covered.
The bad news is that I will be without red plastic for at least a couple weeks, uh, ... unless you guys would be OK with the quality of the ramp in the photo below..
Quoted from Milton187:I would also like ramps for "Time Machine "
Milton
Curious, is your name really milton?
Quoted from Whysnow:Curious, is your name really milton?
Milton187.... This being Milt.... Pretty heavy, hey dude?
Quoted from Freeplay40:First test of the Hurricane center ramp formed this morning. Went very well!
Very nice!!
Put me down for a couple as well. Star war ramp that is.
This page was printed from https://pinside.com/pinball/forum/topic/freeplay40-ramps/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
