(Topic ID: 150775)
Freeplay40 Ramps
By Freeplay40
5 years ago
  • 4,619 posts
  • 722 Pinsiders participating
  • Latest reply 12 days ago by PinCheese
  • Topic is favorited by 423 Pinsiders
56 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 4619 posts in this topic. You are on page 51 of 93.
#2501 3 years ago
Quoted from Brijam:
I’m in for the red/blue, ramp and visor. Looks sweet!
Does anyone know where new visor decals can be found? I already have the Adv X. decal.
+1 on that,.. Wouldn’t mind new decals for the ramp and visor,.. mine are original and could do with a tidy set!!
#2502 3 years ago
Quoted from mrWol64:
I'm going to reach out to Planetary one more time to see if they want to stock the decals.....
#2503 3 years ago
Message sent to Planetary. I did look on the Planetary website and did see they have the visor decal in stock under Jackbot.
#2504 3 years ago
Will you ship to Australia?
Yes, but I might not be able to ship regular mail with this one. I'll try once I have pieces ready to package but this one might be too big for regular mail.
#2505 3 years ago
Bay Area Amusement has the complete Jackbot decal set in stock.
#2506 3 years ago
Quoted from Freeplay40:
Oh, the visor decal is the same for Pinbot and Jackbot?
#2508 3 years ago
I need a Pinbot visor let me know when and where to send monies!
20
#2509 3 years ago
First batch of blue/red dyed Pinbot/Jackpot ramps.
#2510 3 years ago
Wow lookin’ good!
#2512 3 years ago
Oh wow, that looks amazing. I wish I had a pinbot!
#2513 3 years ago
You should do a F-14 ramp like this with red, clear, and blue!
#2514 3 years ago
Pinbot ramp update... I'm having a local sheet metal company make me a larger stainless steel vat so that I can dye the larger ramps. I've been wanting to try a multi-color ramp for some time so while I'm waiting for the new vat I decided to try it with Pinbot just for fun.
Alright.....now you've done it......
When you make Space Shuttle ramps I want a red/clear/blue one.
#2515 3 years ago
Quoted from dothedoo:
#2516 3 years ago
Hi Freeplay40 ; great looking ramps! Are you intending to make WhoDunnit ramps?
12575C28-B3F5-432E-9702-100498552F9B (resized).jpeg3E2F6FBA-DF31-463D-9280-73DE33FF6D9A (resized).jpeg
#2517 3 years ago
order info?
#2518 3 years ago
Took a couple days off. I have 9 of the Blue Red ramps dyed at the moment. Visited a friend on Friday and got the measurements I needed for the Jack Bot version. The Jackbot will require no riveting as the two gates on the ramp are overhead. However the Pin Bot has two roll over wire forms that are riveted to the ramp. If anyone is interested and would want to send me their 2 Pin Bot switch brackets, I will rivet to the new ramp for free. I will have probably 14 or 15 of the Blue/Red ramps ready this week. I will make enough for everyone but will likely be first come first serve. Since this ramp can be cut for either Pin Bot or Jack Bot I will do a two stage finish on them. First what works for both, then finish what is different secondly as they are ordered. I will also have the Pin Bot Visor and the Lift ramps available as well. It take about a day and a half to do the two stage dye on these and I do them three at a time, but I think the result is worth it!...They look pretty cool. I want to get Pinbot finished completely so I can post photos in the game.
#2519 3 years ago
Quoted from MaxwellB:
[quoted image][quoted image]
The Elevator ramp is technically an injection molded piece, but I do have one here on loan from a friend and we hope to be able to produce a suitable vacuum formed replacement.
#2520 3 years ago
Hi, do you make ramps for Roller Coaster Tycoon? Thanks!
#2521 3 years ago
Quoted from Mustangdvr2b:
Sorry, no.
#2522 3 years ago
The ramp also has 3 flasher domes riveted to it as well....I don’t have means for any of this riveting so that is what would keep me from upgrading.
#2523 3 years ago
Awesome! I can’t wait to order the visor so I can get mine back together
#2524 3 years ago
Quoted from Pinballerchef:
I replaced my rivets with some small nut-bolt hardware and then used locktite to keep them from coming loose.
#2525 3 years ago
I actually have two complete Pinbot main ramps here. On both, the flasher domes are secured with screws. Only the switch plates are riveted. It's really only necessary to use rivets where the ball will roll over them.
#2526 3 years ago
And with screws you can change the dome color if you want to.
#2527 3 years ago
Ok mine are riveted. But I can buy new flasher domes and use screws to secure them in to this ramp...thanks for the info!
#2528 3 years ago
Quoted from MustangPaul:
Good call Paul....Like the rhyme? I think I would look to change the colors of the domes too. $1.25 at Pinball Life.
#2530 3 years ago
Just drill them out.
Or just use your advice....
#2531 3 years ago
Fantastic. There will be many wanting them I think.
#2532 3 years ago
Well not screws some tiny bolts and nuts. I added mini domes on my Avatar LE and used little bolts and nuts. The screws are stock and attach the stock cover to the bumper body.
#2533 3 years ago
Count me in for W?D elevator ramp!
#2534 3 years ago
Would you ever consider it? I’d buy one!
#2535 3 years ago
Thank you, thank you for trying! I'm sure there are a lot of W?D owners anxious to get that! I certainly am, I think that piece is in rough shape on most of the machines given the amount of abuse it takes. Given the design, I'm wondering if percentage wise, that ramp gets hit more than any ramp in any other machine. I'm thinking about modes like Penthouse Party where that ramp just gets hit over and over and over.
#2536 3 years ago
Is there any interest in a new minimalist decal mod for the transparent blue/red pinbot ramp? I have an idea to do something in black vinyl that pays homage to the original design, but allows light to shine through. I've aquired some high resolution scans of the original stickers in order to do this.
#2537 3 years ago
Sounds cool, a transparent decal would be awesome. Id be in.
#2538 3 years ago
Quoted from chaskett:
I reached out to Rick at Planetary last week inquiring if they would restock the ramp decals for Pinbot and got no response. The original decals can be removed and put on the new ramps, but I think something like Chaskett is describing would look better given the transparency of my ramps.
#2539 3 years ago
Yes please
#2540 3 years ago
Haven't seen the art but I like the idea. I'm in too.
#2541 3 years ago
Here's what I was thinking. This would be large transfer decal in glossy black vinyl. Therefore all the stars and everything white would be the blue ramp. I'd do something similar for the right which would glow red. What does everyone think?
#2542 3 years ago
Do you have any Robocop Jump Ramps? Thanks
#2543 3 years ago
Just adding my vote for a Jurassic Park main ramp. Philip J. Fry voice, “ Shut up and take my money!”
#2544 3 years ago
Are WCS ramps coming in the future? A previous owner flame-polished the ramps on the one I have and made them all wavy. Ball gets stuck in the divets.
Very shiny though!
#2545 3 years ago
Quoted from jahbarron:
Very shiny though!
The WCS ramps should be coming from Starship Fantasy soon.
#2546 3 years ago
Not to sure I would believe there is anything coming from starship fantasy. Larry told me about 3 months ago that the new boulder sets for white water would be for sale in 3 weeks. Here we are over 2 months later with NO new boulder sets. Just saying!
#2547 3 years ago
Sweeeet
#2548 3 years ago
Looks nice!
#2549 3 years ago
Sorry, late to the party, I got a space station ramp from you awhile back, and it was awesome. Any plans on doing space shuttle? Those ramps are brittle, and I could use a new set for mine.
#2550 3 years ago
I just bought a set of NOS Tx Sector Ramps for my game. Any interest in reproducing these? I could send you my ramps before I install them?
