UPDATED 2/7/2021
Currently offering the following ramps in clear and in dyed PETG. Most ramps at this point are made on demand.
High Speed – Redesigned to eliminate the cover. Available in clear ($90) or transparent red ($100). Assembly services offered $20 Spring Steel ball guide $5 Molex extension for Stop Light $8
Space Station – Transparent blue “plug and play” ($145). Ramp is complete including new micro switch and Molex harness to plug into the game harness
Genesis- Two ramp clear set ($165 for both)
WWFRR- Banzai ramp. Designed for greater strength at the exits ($120). New Lexan clear cover ($12)
Heavy Metal Meltdown – Ramp and cover $145. New flap $13 Material twice as thick as original.
Swords of Fury – Available in clear, transparent red and transparent blue. Upper ramp clear $135 lower ramp clear $40. Colors Add $10 upper/$5 lower. Assembly services offered for upper ramp $25
Whirlwind - Lift ramp - $45
F-14 Tomcat – Clear $90 Red or blue $100 Assembly service offered $20
Hurricane – Center ramp including new cover $140 Includes all brackets
Data East Launch Button housing $25
Strange Science – Particle Separator ramp $110 Anti-Gravity ramp $45 Anti-Gravity Exit ramp $42
Guns and Roses – G ramp $155 R Ramp $125 (includes new cover) BACK IN STOCK 8/10/2020 - Limited run
DE Star Trek 25 – Subway ramp $80 (no hardware) $98 with all hardware
Rocky and Bullwinkle – WABAC ramp $115 Ramp has two unique brackets…if sent to me I install them for free
Hook - Rufio ramp $90 50% thicker plastic and includes the extended lower ramp protector like on MNF
Doctor Who – Time Expander cover $45– 50% thicker plastic
Comet – Transparent orange Cork Screw ramp $80 Cycle Jump ramp Black ABS $60 Transparent red $65
Pinbot/Jackbot – New complete lift ramp assembly, new main ramp in transparent colors and two color (Blue/Red) and new visor
Black Belt – New transparent red ramp
Transporter – Upper left ramp, right ramp and Cross-Over cover.
Radical - Upper left ramp (Both versions) and the Vertical ramp and Vertical ramp cover.
Black Rose Whirlpool ramp and left ramp
Next up...
Comet Center Ramp
3 Remaining ramps for Radical
Demolition Man - Three playfield ramps. Cryo-Crawl ramp, Subway ramp, Auto Tunnel.
