(Topic ID: 128426)
Freddy Nightmare on Elm Street Owners Club
By amendes
  • 585 posts
  • 84 Pinsiders participating
  • Latest reply 7 days ago by fatality83
  • Topic is favorited by 28 Pinsiders
There have been 169 images uploaded to this topic. (View topic image gallery).
There are 585 posts in this topic. You are on page 12 of 12.
#551 4 months ago
Quoted from hailrazer:
The Flash bulbs are used a lot in attract mode, so they blow out often. Also the sockets on Freddy can be very problematic. They might need replacing.
The transistors will go bad on the driver board. I had 2 locked on and 2 open that needed replacing. The easiest thing to do is take the board out and test all the bottom transistors and replace the bad ones.
Thanks I am going to test the transistors this weekend and post the results. From what I see the freddy eyes transistor is commonly blown because of the sockets touching each other and shorting out.
#552 4 months ago
Q21 is burnt and bad on the driver board. All other transistors tested good. Control board looks in really good condtion. I tested voltage at the boiler room motor and get 20 volts for the time the motor is running (a second or two) Once the motor stops so does the voltage. I tested the transistor on the motor board and it is reading .50 like it should. I unplugged the pigtail that plugs into the motor board. The larger pigtail that goes to the control board I assume and tested voltage with it unplugged. With it unplugged, I get 23 volts for around 15 seconds immediately upon turning on the game. Once the GI relay clicks in the cabinet for the back box it drops down to 0 volts. So I assume the machine should be moving the door up and down for around 15 seconds when the game is first turned on (mine doesn't). If I start a game with this connector unplugged and no balls in the game, it shows 23 volts for around 30 seconds. It does several ball searches. Eventually it drops down to 0 volts. When the final ball search is performed before the ball stuck call technician message comes up it jumps back up to 23 volts again as I guess the cpu is commanding the motor to move to try and free the "stuck" ball.
If I plug this connector back into the little circuit board that mounts on the bottom of the motor and keep the multi meter probes jammed in the connector. I get no voltage when the game is first powered on. If I start a game it jumps up to 23 volts for about a second while the door cycles and then immediately drops to zero. So with the connector in, the control board is only commanding the motor to run for about a second. No idea why it seems to command the motor normally when this connector is unplugged but only turns the motor on for about 2 seconds when the connector is plugged in.
I suspect that either the motor is trying to draw to much current or something is wrong with the little circuit board that is on the bottom of the motor. I have a new motor coming today so we will find out if it is the motor.
#553 4 months ago
Well I guess I got it figured out but not sure what fixed it. Don't you just hate those kind of repairs? It was either a stuck switch on a drop target or a loose connection on the motor or one of it's switches. I tried running the game with the switches unplugged to see what that did. I plugged the switch wires back in and went into switch test to make sure they were working again When I was in there I saw that drop target 2 was showing as being down even though it wasn't. I adjusted the leaf switch so it wasn't registering when down and much to my surprise the door started working like it should. I have played about 30 games so far and it has stayed working. I even was near the motor wiring as I had to install two screws in the motor bracket and i know I was bumping the motor and switch wires but it still is working so IDK.
Still having an issue with the flashers in the boiler room. If I have one bulb in it flashes but it isn't as bright as it should be. If I put a 2nd bulb in the other bulb holder neither of them work, or they work but barely and I mean barley flash. Also the boiler room and freddys house are flashing together when in flasher test mode. They should flash separate from what i understand. I ordered two new flasher sockets from marco, we will see if that changes anything.
Can someone post a picture of their left ramp. I replaced mine but don't know how the ramp mounts to the metal bracket underneath. Is it supposed to be riveted on with metal rivets. Also should there be foam where the ball lands on the ramp from the up kicker?
#554 4 months ago
come on freddy owners "get the lead out!"
#555 4 months ago
Any ideas how the claw flipper comes off? I want to replace the broken claws on mine.
#556 4 months ago
Quoted from fatality83:
You loosen the set screw on the flipper mech underneath the playfield and slide it out. Just like any other flipper bat.
kicker?
Yes there is a piece of foam. It covers what looks like to me are rivets.
#557 4 months ago
Thank you!
#558 3 months ago
Does anyone have scans of the target decals?
#559 3 months ago
Quoted from Shredso:
PBResources sells them all very cheap.
#560 3 months ago
I posted this in it's own thread, but I'm getting crickets so I'll duplicate it here as it might be game specific. Any help is appreciated, I know I'm missing something stupid easy.
I'm down to the last (I hope) major issue on my Freddy project. The glove flipper isn't working. This is a little challenging to troubleshoot. There is no flipper test in solenoid test, and the glove flipper only works when a relay is activated. The good news is, this is a simple flipper system and I'm totally stumped as to why it isn't working. Glove Flipper relay works in diagnostics. Pressing the relay manually gets me voltage on all 3 lugs, 62v (the other coils are getting 66). Grounding the non banded side of the other flippers activates the coil. Grounding the non banded side of the glove flipper does nothing. This was done while holding in the relay, there is voltage at the coil. The coil is brand new from PBR. I'm getting 4.5 ohms across the outside lugs. I'm getting 5.2 on the right flipper coil, and 16 ohms on the left flipper coil. This is clearly odd. Lower flippers work fine, and I think they are both new coils as well. Any ideas? I suppose I could swap the glove flipper coil to a known working setup, but I'm confident the coil is fine.
#561 3 months ago
I would try swapping the coil with a known working one. If your getting power up to the coil and you ground the non-banded side, it should fire. Just because the coil is new doesn't mean it isn't good. I would definitely swap it with a different one to see what you get.
#562 3 months ago
I rebuilt my claw over the weekend using lexan and silver paint. It isn't perfect but it came out pretty nice and looks a heck of a lot better then it did.
I also added a couple leds that I had left over. Just need to order more and a rubber kit for it. I did notice some of the leds I added were ghosting. Seems like this game will ghost more then others.
I have one last issue to troubleshot. I made a new post about it. Can someone help? Basically my boiler flashers and house flashers are shorted somewhere. They are flashing very dimly barely even noticeable. If I have two flashers in the boiler then non of them work. Here is a link to my thread I started. I hope someone can give me ideas where to go from here.
https://pinside.com/pinball/forum/topic/need-help-understanding-this-wiring-schematic
#563 3 months ago
I swapped the new coil to my left flower flipper and the known working coil into the glove flipper coil. No change. Can someone confirm if holding in the relay in solenoid test and pressing the flipper button activates the glove flipper coil?
#564 3 months ago
So your in test mode and on glove relay and hitting starting and the flipper button at the same time or are you holding the relay shut with your finger and pressing the left flipper?
#565 3 months ago
Holding the relay shut with my finger. The relay operates in test mode, but it only pulses the relay.
#566 3 months ago
Ok I will check this for you when I get a chance
#567 3 months ago
Solved! It was either the Q relay or the glove flipper relay was dirty. Just in case anyone else has this issue, holding in the relay, the glove flipper does work in test mode.
#568 3 months ago
Awesome glad you got it figured out!! Sorry I didn't get to test mine yesterday, I had a 14 hour work day. Well pretty much do every day. Can you do me a favor when you get a chance? Test your house and boiler room flashers in solenoid test and tell me if they are flashing separately or together. I have an issue with mine where they are trying to flash together. The boiler and the house both flash or try to at the same time whether I am testing the house or boiler.
#569 3 months ago
Mine flash individually in test mode.
#570 3 months ago
My boiler room opto and left orbit opto sometimes won't register fast shots. The optos are clean. I know this is a design flaw on some games, does anyone else have this issue?
#571 3 months ago
thank you!!
#572 3 months ago
Does anyone have or can get a scan of the playfield where flippers are? Mine has some worn paint off and I was thinking of printing a decal and putting mylar over?
#573 3 months ago
Todd did an interview with Billy Parker who helped design Freddy. Interesting interview. He said at one point the claw was supposed to have individually moving fingers that would lock balls.
#574 3 months ago
https://pinside.com/pinball/forum/topic/freddy-nightmare-on-elm-street-playfield-scan#post-5048146
3 weeks later
#575 75 days ago
Just joined the Freddy club! I love this pin and think that it doesn’t get respect. It’s a good value and has some great call outs! Anyway, what kind of mods have you guys done? It would be cool for someone to create a sound mod that incorporates actual movie quotes, but I’m not sure how easy/hard that would be.
1 month later
#576 41 days ago
If anyone is looking for a freddy that in Maryland message me. I have one on hold that i need to pay off to pick and something came up. So trying to get it paid off and what i have into it back.
#577 21 days ago
Looking for a nice example of Nightmare on elm street.
Not a players condition
#578 21 days ago
Quoted from Pinchild:
I might have to sell my super nice one to free up some room. Only problem is I sold it once before and had to buy it back because despite not playing it much I missed it in the collection.
#579 21 days ago
Just switched over to LEDs and it is looking great! I'm not able to figure out how to get Freddy's head off to change those bulbs though, and I don't want to get too rough with it. Has anybody removed Freddy's head, and if so..how?
#580 20 days ago
Sort of piggy-backing on top of the last comment -- I'm thinking of putting LEDs in my Freddy. I typically source them from Comet and I'm wondering for those of you out there that have done the LED swap, can people speak to what 'flavor' of LED in terms of the light type (cool, warm, etc, etc) works best for the table. I just put 'sunlight white' in my early Bally Silverball Mania and the light quality is nice and warm. The Freddy table is currently quite dark with the stock incandescent bulbs, so I do want to brighten it up but don't want to make it overly bright and entirely lose the dark Freddy feel.
Any suggestions?
#581 16 days ago
Quoted from kerpess:
There is a black metal plate that is over the 4 or 5 faces in the neck target. Remove those two screws, the black plate will lift off. You should then be able to see the two screws that hold freddys head on to the left of his head
#582 15 days ago
Which kind of LEDs did you use in yours? Frosted? What intensity?
#583 7 days ago
Gameplay question for owners out there. Does anyone ever shoot for the TV? I forget what the reward is in points, but it seems like real dangerous center-drain shot so I never shoot for it. Sort of related does anyone ever go for the specific features that are highlighted on the DMD when in any of the nightmares -- as opposed to just working towards beating Freddy? I know for certain nightmares the Freddy 'soul shroud' targets or the drop targets become more valuable.
Any game play pro tips?
#584 7 days ago
Quoted from malkneil:
Gameplay question for owners out there. Does anyone ever shoot for the TV? I forget what the reward is in points, but it seems like a real dangerous center-drain shot so I never shoot for it. Sort of related does anyone ever go for the specific features that are highlighted on the DMD when in any of the nightmares -- as opposed to just working towards beating Freddy? I know for certain nightmares the Freddy 'soul shroud' targets or the drop targets become more valuable.
#585 7 days ago
I normally don't try to hit the tv as it is risky shot as you said. I mainly shoot for jackpots and work on building up krugarends and trading them
$ 16.95
Gweem's Mods
$ 179.00
Id Rather Play Pinball
$ 249.00
CzTV Mods
$ 36.99
Lee's Parts
$ 27.99
Flashinstinct
$ 99.99
$ 19.95
$ 29.99
Lee's Parts
$ 7,500.00
