I am thinking of replacing the lamp column driver TIP42's on my 1986 System 11 Space Station. The associated 27K ceramic resistors show considerable charring on the board. I understand that these mosfets reduce the heat on the resistors which sounds like a worth while improvement.
After doing a bit of research I am uncertain of what to do about the resistors (R82-R89).
John Wart suggests replacing with 0 ohm resistors or wire jumpers.
barakandl recommends replacing with 1/4w resistors in a low ohm range. Like 22-270 ohm to maybe absorb a blow if some oh shit thing happens
Chris Hibler has a more complicated fix to reduce the voltage in the mosfet by using two resistors (one on the back of the board) See pinwiki
Others just leave the ceramic resistors
I respect the opinions of all of these pros which puts me at a quandary.
Are there any other opinions or relevant suggestions out there?
