First Pin, First problem. I got this Firepower 2 last week and after a few days the credit button stopped working, and upon further investigation found the entire row wasn't working. Same problem as seen here - http://pinside.com/pinball/forum/topic/switch-matrix-question-williams-system-7-firepower-ii
Turned out the white wire on the credit button was just about to fall off, and in fact when i touched it it did fall off. I soldered it back into place Bob's your uncle I was back in business. After 2 more days, same problem. Checked the soldering, looked good, wiggled the wire a bit, button started working. Next day, same problem, no amount of wiggling fixes it. I removed the solder, and tested it before I resoldered and everything was fine. Soldered it back up, and it doesn't work. Removed all the solder, and now maybe 5% of the time when I hold the connection manually i can get it to work. I'm out of ideas, and sick soldering in this tiny corner. Any ideas? I'm stumped.
