(Topic ID: 206827)
Found this in my WOZ cabinet
By ryanwanger
2 years ago
  • 18 posts
  • 11 Pinsiders participating
  • Latest reply 2 years ago by TheArrrrrcade
#1 2 years ago
Seems like this was probably important. What is it and where did it come from?
#2 2 years ago
That's a capacitor. It looks like the one's used on PC motherboards.
#3 2 years ago
Quoted from ryanwanger:
Is it the whole cap cylinder or just the round flat top? Here's what the whole thing should look like from a Nichicon data sheet.
Probably from the PC motherboard...
#4 2 years ago
The first thought that came to mind for me was the overheating power supply issue. A quick look shows that the caps nearby that inductor are not the same value, though.
#5 2 years ago
I found one in my cabinet too. Could not figure out where it came from but I assumed from under the playfield.
I'll take a picture when I get home.
#6 2 years ago
If it is in the cabinet but not in the metal computer box then it makes sense that it likely came from a board on the playfield. Some places to look at are the opto control boards and the large light boards.
#7 2 years ago
Could it just be something that got dropped in there during assembly and is not from the boards in your machine? Has anyone ever seen a component just fall out of a board? I would think something would have hit the board to have it drop off and in that case the boards should have an obvious ding. I would think if you lost a capacitor it would exhibit some errors in functionality.
#8 2 years ago
Quoted from Jesterfunhouse:
I can't imagine why a cap like that (if it is the entire cap and not just the lid or something) would be anywhere near the cabinet during assembly in order for it to have been dropped in there. More likely it fell off one of the under PF boards during shipping. This definitely can happen with larger surface mount components if there was insufficient solder paste during reflow or it just didn't adhere well for some reason. That being said I don't really know if that type of cap is even on any of the underside boards as I've never looked at them that closely.
#9 2 years ago
This is absolutely a SMD capacitor. I use these in my work regularly. It was likely knocked of the pcb board accidentally. A missing cap may not show an immediate error. It really depends on the function of the capacitor. These types of caps (Electrolytic) are commonly used to stabilize line voltage and/or provide a short boost of current. Finally, I think there is a common mis-conception that soldering is like welding and it's not. Although there is a mechanical connection made with solder, it's very weak and breaks easily. The purpose of soldering is to make a good (low resistance) electrical connection not a mechanical connection.
#10 2 years ago
Quoted from bobukcat:
Agreed. This type of cap should only be loose during PCB assembly, which happens at a completely different location from cabinet assembly.
#11 2 years ago
Only caps under the playfield with that design I can find, sits right above the cpu case.
My caps say 100 VFK 515 though
#12 2 years ago
Quoted from Slim64:
That is WOZ 2.0, correct?
OP, do you have a WOZ 2.0 game?
#13 2 years ago
Quoted from DCFAN:
It was in the cabinet...however, I realized that this could be from when my power supply overheated, as in Herg's photo. I replaced that board.
Quoted from DCFAN:
What makes something WOZ 2.0, build date?
I'll look around some more to see if I can tell where this came from. The game was on location and blowing fuses (sometimes GI, sometimes coils), so I brought it home to work on it. Might be related, or could be a coincidence.
Sadly, the ceiling in my basement is a few inches too short, so it makes looking around in the cabinet and under the playfield a huge pain (although I'm able to fully raise the PF on all the other games I have).
#14 2 years ago
Quoted from herg:
You need to open a ticket and see about getting the updated unified power supply board.
#15 2 years ago
Quoted from LTG:
I sure hope that is not his current board as the R88 is fully off and it seems burned. Probably he already got a new one ??
#16 2 years ago
Quoted from DCFAN:
Yes, 2.0
#17 2 years ago
Quoted from LTG:
Mine had been updated, and that's not a picture of my board. It was only an example to show why I originally thought that may be where Ryan's cap came from.
#18 2 years ago
It's the same one. I don't have a 2.0, it's the 7.5v light system.
This may have come off the fish board (WOZLED1) There are a couple of SMT 16v caps on that. Mine was causing problems and had to be replaced.
$ 48.00
$ 22.50
Magazines/books
Pinball Magazine
$ 85.99
$ 50.00
Escondido, CA
