(Topic ID: 7330)
Forward Nudge or Sideways Nudge for Outlanes?
By Crashdance22
7 years ago
  • 16 posts
  • 14 Pinsiders participating
  • Latest reply 7 years ago by jackofdiamonds
    Topic poll
    “How should a player nudge to avoid outlane drains?”
    • Forward nudge 17 votes
      61%
    • Sideways nudge 11 votes
      39%
    (28 votes)
    #1 7 years ago
    I've been trying out the forward nudge lately, but this can sometimes bounce the ball off the dividing wireform and into the outlane. Which method do you think is best?
    #2 7 years ago
    depends on the type of outpost, angle ball is entering at, how good you are, how sensitive the tilt is set ...
    #3 7 years ago
    Quoted from davewtf:
    Well said, +1 on that. If you do a forward nudge at the wrong time you could very easily kick it into the out lane the exact opposite thing you want to happen. I think the forward nudge takes a better timing and more finesse to execute but really depends on the situation/setup of the game.
    #4 7 years ago
    I like to do a forward nudge when the ball is about to hit the top of the slingshot. If timed correctly, it will propel the ball away from the area. The side nudge comes in handy when the ball is already bouncing near the outlane, and it looks like it's going to drain.
    #5 7 years ago
    I would say both depending on what the ball is doin
    #6 7 years ago
    Quoted from gweempose:
    Big +1 on that.
    #7 7 years ago
    Good post, maybe I'll experiment a bit.
    #8 7 years ago
    Yeah exactly, but for the most part I am nudging forward when the ball comes anywhere near an outlane.
    #9 7 years ago
    Quoted from Crash:
    Crashdance, if the lane divider has a rubber post you want to nudge forward so the ball goes off the post and out of that area. If you are forward nudging but the ball is still bouncing around the inlane/outlane, you aren't nudging hard enough.
    If there's no rubber, like on a toughened up tourney game, you have to nudge a bit harder.
    If the ball is already settling in the in/out lane area, then side to side is needed, but ideally you don't want to put yourself in that position to begin with because no matter how good you are it's tough to reliably recover the ball.
    On many EMs there is just a simple wire divider. Unfortunately, they are very good at dissipating force and a forward nudge is often useless. On these you need to anticipate the balls travel and slide the game left/right as needed to get the ball into the inlane.
    #10 7 years ago
    If the ball is in the outlane use side to side nudging.
    #11 7 years ago
    Quoted from jonnyo:
    Pretty much right on...
    Always try to be "proactive" rather than just "reactive" when the ball gets bounced around on the slings, it's just a matter of time before it wants to go cruising downtown via the "scenic" route...
    I will usually include a little bit of side when using the forward nudge on a (outlane) floating ball.
    With that being said...
    I find that if the ball is heading towards an outlane and is pretty much a "guaranteed" drain- trying to get the inlane under it (or at least a piece of it!) before the ball actually reaches the post/divider usually works better than the forward nudge. The ball is after all "WILD", so use "Eye-Geometry" whenever you can... Sometimes it is a tiny shift, sometimes it takes moving the machine!
    One TILT warning won't hurt...
    #12 7 years ago
    Quoted from NimblePin:
    I think it may have been Bowen who said that when the ball gets going between the slings he likes to nudge the game forward to help get it out of there. This is some great advice, as most players just passively watch in utter helplessness.
    2 months later
    #13 7 years ago
    check the sticky at the top of the forum...great video up for your question up there.
    #14 7 years ago
    +1
    #15 7 years ago
    As many have said, both are appropriate depending where the ball is and what it's doing... For me, typicaly forwards initially to try and bounce the ball away, and if it's hovering above the outlane, sidways is all that can help...
    It should have been a multiple vote option poll, because personally I really can't decide on either...
    #16 7 years ago
    I tend to "push".Very rarely do I go side to side.So I'll vote forward since it's what I do most often.Scott
    $ 8,000.00
    3D MODS
    $ 66.95
    $ 5.00
    $ 4.99
    Playfield - Plastics
    Pinball Photos
    $ 259.00
    Tilttopper
    $ 22.00
    $ 11.95
    $ 59.95
    pinballmod
    $ 150.00
    Republic Of Pinball
    Pin Monk
    $ 24.95
    The MOD Couple
    Lee's Parts
    $ 9.99
    $ 5.00
    Doc's Pinball Shop
    $ 42.00
    The MOD Couple
    $ 48.00
    Lighting - Under Cabinet
    $ 269.00
    Displays
    Boston Pinball Company
    $ 99.99
    Filament Printing
