THE MOST IMPORTANT adjustment you can make to your game that I've seen no one mention or talk about (edit: I was informed Jack Danger mentioned this in a stream)
Full and Auto Plunge shooter lane adjustment:
It's built into the game but surprisingly hidden and not in the manual either in written or pictorial form. I found it when I took apart my shooter lane to install the post sleeve at the end of the shooter lane.
I don't have a pic of it because my lane is dialed in at 7.0 pitch and goes around the ramp 100% of the time manually and on auto and I don't want to mess with it anymore (see the post below a couple down from this one where I found it in Cary Hardy's video at the 11:05 timestamp)
1st off you don't have to take apart anything to make this adjustment, but it is intended to mechanically change the shooter lane. The following is if you want to take a peek at what I'm describing
There is a single 11/32" nut holding down the end of the right shooter lane, right ramp and post sleeve post. Unscrew that nut and remove the washer, pull up the metal return ramp, remove the other washer and black spacer and you will see a slotted adjustment at the end of the ramp...the guide end is flexible and rides off the playfield with a built in clearance notch so you won't scratch anything...The movement is about 5 or 7 mm left and right...you can see where I lined mine up in the overhead photo.
To make the adjustment:
Reassemble everything if you did my step above, otherwise, simply loosen the nut until you can move the end of the guiderail back and forth freely. It has limits of travel within the slot and will only move so far one way or the other. Snug the nut up and do a series of tests...I start with manual full plunge and get it to where it's just missing the ufo ball and cleanly hitting the ramp...then move onto the auto plunge...running a series of test over and over in rapid succession...you may find you are coming up short when the manual is dialed in...At 7.0 degrees, I bumped my autoplunger power from the factory 210 default to 225...
Every game is different but I can assure you you can make both your manual and auto plunge work 99.9% of the time and complete the ramp cleanly
It improves the game dramatically by reducing chaos drastically.
Added 8 months ago:
I changed my pitch to 6.8 recently and the above tweaks still hold up
