Fluttering problem on top flipper
(Topic ID: 8894)
By Fishmugger
7 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by pinmike
#1 7 years ago
New to this hobby and trying to repair all problems on my Fireball 2 pin. Teaching pin repair myself and have lots to learn. I enjoy the challenge as retired and need something to fill my time.my problem is 3rd flipper on top of play field flutters when you hold down left flipper switch. I understand how the coil works and checked small wire on coil and seems ok. Is this hold coil activated by contacts on lower flipper ? where should I look ? This form is awesome wealth of knowledge and would be lost without it.
#2 7 years ago
Check the EOS switch on that flipper
#3 7 years ago
Sounds like the low power coil isn't being used.
There are three wires coming from the coil, a common (power), and two drive wires (1 for high power for the flip, and one for low power to hold it up). Check that both of those wires are connected properly, and check that the low power coil isn't an open circuit or something.
Someone's probably going to suggest the EoS switch, and that should be checked, but if the flipper is fluttering, the EoS switch is probably working fine - the flipper is falling, the machine is detecting it, and using the high power coil. The problem is the low power coil should be on, so the flipper won't fall.
#4 7 years ago
Checked the EOS switch ,work fine .what I'm asking is what activates the low power coil? EOA switch contacts are set closed on the upper flipper .there are only one set of contacts on EOA on this flipper.
#5 7 years ago
Is the wiring on the correct lugs of the coil?Is the nylon coil frame in
go shape?Did you test the coil/diode with a meter?Also a worn coil stop can
cause these kinds of issues.
€ 3.95
Multigame
Third Coast Pinball
$ 16.00
Yorktown Parts and Equip
Displays
PinballSolutions.eu
$ 29.99
€ 15.00
FLIPPROJETS
$ 24.00
Pin Monk
