A customer brought in an EM Gottlieb 4 player "Surf Champ" for restoration. It belonged to the guy's parents and had been in a flood 15 years ago in which there was 5 inches of water in the main cabinet. He said they had gotten it out of the water quickly and had opened it up and dried it out right away. He said it had not been plugged in for those 15 years until just about a month ago. It did not reset so he started to "fix" it himself by cutting all the wires to the "S" (start) relay, adding a bunch of wires, adding a terminal strip, and jumping wires across the terminal strip. Naturally that did not work and then decided to bring it to an expert like me to repair it.
First thing I saw before even opening the machine was that the machine had been completely covered in WALLPAPER! It was horrible! His dad did that because he didn't like the cabinet graphics. Opening up the coin door showed it to be corroded, but not too badly. Looks like I will need to disassemble the coin door and run the metal parts through some C-L-R and Evapo-Rust. The bottom cabinet panel and the relay/score motor panel were completely covered in dried mud/silt. The stepper unit on the relay panel is all gunked up with dried silt, but not really corroded. The machine is definitely salvageable.
The playfield is in great shape but needs the usual cleaning and rubbers. The flood waters never even got close to the playfield or the backbox. I opened up the back door on the backbox and everything looked normal back there....no flood damage at all.
I'm attaching pictures of the horrid wallpaper covering and the silt covered relay panel (taken out of the machine). I have already removed that wallpaper and found absolutely beautiful condition original cabinet artwork intact. I've removed that cluster of home made wiring and returned the start relay wiring to factory spec. Next thing to do is start on scrubbing the dried silt off the wiring harness and everything else on the relay panel before washing everything.
Surf Champ front.JPG Surf Champ side.JPG Surf Champ relays.JPG Surf Champ stepper.JPG Surf Champ motor.JPG Surf Champ jacks.JPG
