Problem: Dr. Who WPC Fliptronic II board blowing fuse #F904 which is to the left upper flipper. Fuse blows during flipper test mode or if machine is allowed to power up into normal ready mode. All other flippers function correctly.
Trouble shooting repairs: Confirmed coil tab wiring correct, Replaced coil as cautionary measure, Confirmed continuity in wires from board to coil, upgraded flipper board to Rottendog model.
Problem still present!
I am thinking possibly at this point that my J907 or J902 plug could possibly have a wire or two in the wrong pin location. I switched harnesses during my restore and no longer have the original. I attempted to cross reference the wire color pin placement with the Dr. Who manual fliptronic schematic section but honestly I could not pinpoint a confirmation or refute to my current set up. The pictures and pin# were confusing in their presentation. Could someone verify my pictures of these 2 plugs and their correct wire slot locations and / or some suggestions to tracking down this problem??? I am stomped at this point on a solution.
