So I am finally getting my HS2 going, and I've been enjoying playing it but I found that I couldn't stage my lower and upper right flippers. Just making the first switch contact on the double switch stack powers both flippers.
When I checked with my multimeter there is continuity between the power wires (black yellow for upper, blue violet for lower) at the coils. So then I pulled J902 from the fliptronics board and tested from the connector end - also a short.
Should I be looking for a hack on the wiring harness, or worn insulation, or is this normal behaviour ?
John
