(Topic ID: 293677)
flippers wont stay tight
By Matthew2015
1 year ago
#1 1 year ago
seems like i cant seem to get the set screws to hold the flipper shaft tight .
i am using a Hollow Round Shank Nut Driver with torx bit but it hard to reach the bolts with having to screw them in sideways.
i am using the set screw that came with a the new flipper mechanisms which have cone ends instead of points.
is there a there a different kind of screw that would work better?
and what kind of tool and size would work best?
#2 1 year ago
What game and manufacturer. To help get better answers.
#3 1 year ago
Torx screws? Seems like they should be Allen head screws. Allen screws would allow to use an offset Allen wrench, which will give you all the torque you need to get them tight.
Did you replace the flipper bats? I don't recall what they used for Flash, but specifically the flipper shaft (that you're tightening to) is often in rough shape.
#4 1 year ago
this is for a flash pinball machine .
the flipper shafts did have small nicks in it from where the set screw were.
the set screw are Allen wrench's but i don't have the right size.
using the set screw included with this flipper rebuild kit.
#5 1 year ago
Without the correct size, you will never get them tight enough. Worse yet, you can damage the screws and then really be in a bind.(Pun intended)
#6 1 year ago
As I recall, the setscrews likely use either a 1/8" or 9/64" Allen wrench. If the setscrews are working loose, then apply a drop of blue LocTite to the threads.
Pinball Resource's flipper rebuild kits usually come with the correct Allen wrench in the kit.
#7 1 year ago
You've got to crank that style down to 75 inch pounds
You can use a ratchet with the proper bit
Those "ball end"" bits allow you tighten the bolt with the ratchet at an angle (good for clearing over other mechs under the playfield)
Craftsman always has those kits on sale for $20
https://www.sears.com/craftsman-24pc-reach-and-access-add-on-set/p-A011456050
#8 1 year ago
thanks for the advise , i do need to get the proper bit for my ratchet which is a 1/8 hex for a 3/8 drive socket.
#9 1 year ago
Quoted from Matthew2015:
Don't get that Craftsman set then, as the smaller sizes are 1/4" drive
instead maybe:
https://www.harborfreight.com/38-in-drive-sae-long-reach-ball-head-hex-socket-set-7-pc-67885.html
#10 1 year ago
thanks i will able to tighten flippers enough to where they work great.
$ 69.99
Pinball Shark
Shooter rods
Tools
Pincoder Store
Tools
KAHR.US Circuits
$ 14.00
$ 52.99
Pinball Shark
Shooter rods
$ 9.95
Playfields
Troxel Repair
Playfields
$ 27.95
1,400 (OBO)
Nazareth, PA
Other
Men
$ 11.00
This page was printed from https://pinside.com/pinball/forum/topic/flippers-wont-stay-tight- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
