New! Dark mode!
(Topic ID: 255276)
Flippers Weak/Strong/Weak - WPC Flintstones
By smileymatthew
11 months ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 11 months ago by zacaj
#1 11 months ago
I cannot figure this out - and what's causing it.
Having an issue on Flintstones... The Lower Right Flipper is always perfect, but the upper right and lower left (Seems to happen at the same time) will be fine, then they both get really weak, and then they go back to normal. This has happened several times and will happen several times during the same game. I swapped out the Flipper Opto board in the back with a different one but the weird behavior returned. Game has a new Driver Board in it as well.
Game appears to have new flipper coils in all three flippers. Any help would be greatly appreciated! I'm lost!
#2 11 months ago
Quoted from smileymatthew:
Check the ground plug on the power cord.
Try another outlet in your house
Check voltages at coil lug. The coil I believe needs 50vdc but may register much higher when not under load.
#3 11 months ago
Try cleaning the flipper switch optos
$ 194.99
PinballBulbs
5,000 (OBO)
Woodstock, GA
$ 229.99
