(Topic ID: 76247)
Flippers causing WOZ to score points
By WesleyCowan
6 years ago
  • 13 posts
  • 10 Pinsiders participating
  • Latest reply 6 years ago by haiderdj
#1 6 years ago
Almost every time I activate the flippers I'm getting scores on my WOZ. Doesn't matter if it's only the bottom flippers and does it on left and right side flippers. Suggestions please?
#2 6 years ago
Put the game in switch test - hit the playfield with your hand, does a switch activate?
#3 6 years ago
Sounds like a switch is too close together and the vibration is causing them to touch.
Go into switch test mode and bang on the Playfield a little bit. See if any switches register that shouldn't.
#4 6 years ago
Did the hit the playfield and found Scarecrow and Spinning House Step would activate. Scarecrow seems straight forward enough but where is the Spinning House Step switch located?
#5 6 years ago
Quoted from WesleyCowan:
It's on the house mech. Don't worry about it; it doesn't score.
#6 6 years ago
Keep flipping! You'll finally get a high score on your game!
#7 6 years ago
Quoted from SilverBallz:
I started doing this once on a routed spiderman. Got to like 1.8 billion and then saw that the grand champ was up over 5. I walked away at that point.
#8 6 years ago
My thoughts exactly; why fix something that benefits you as a player.
#9 6 years ago
Quoted from MrBally:
Because it's not how the game should work
#10 6 years ago
Quoted from markmon:
Thanks, I didn't realize that.
#11 6 years ago
Just leave it alone and be thankful everything else is working good.
#12 6 years ago
I have a much older machine and have had major vibration problems from the get go. Originally, I didn't realize anything was wrong and was racking up huge scores. Then when I figured it out and fixed the problems by adjusting the switches, my scores became much more modest, and the game became a lot more fun to play.
#13 6 years ago
Those dang pinball flippers! Always trying to make a quick buck....
$ 399.95
Pin Stadium Pinball LEDs
