New! Dark mode!
(Topic ID: 276350)
Flippers cause house lights to dim
By ypurchn
50 days ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 50 days ago by ypurchn
#1 50 days ago
T2 has had an issue where anytime I flip, the backbox lights would dim. I moved the pin about a month ago and now the backbox lights and the room lights on the same circuit now dim anytime I hit the flippers. I’m assuming some kind of board component is failing but I’d appreciate some pointers on where to begin looking.
#2 50 days ago
Are the lights in your room LED?
If so, that can happen if the circuit is loaded up.
LED's can cause RF interference too!
#3 50 days ago
Quoted from PW79:
Yes LED in both pin and room.
15 amp circuit with only 1 pin on and builder grade led light.
#4 50 days ago
When was your house built?
#5 50 days ago
If the lights on game and house stay dim when flippers are held I would check eos switches for flippers. Fuses for flippers maybe overused as well if an eos switch is failing.
#6 50 days ago
Quoted from djd9617:
2015
#7 50 days ago
Quoted from pinballplusMN:
thanks i'll check it out.
$ 259.95
Pin Stadium Pinball Mods
KAHR.US Circuits
