I cleaned and checked the sleeve the stoppers flat and plunger mushroomed. I did a flipper test under test menu right side still good left no power but moves on the test for hold flipper problems or do you think electrical? Thanks Tom
This topic is closed.
What game? A bit hard to tell what the problem you're describing is but it sounds like the left flipper doesnt move at all? Check your EOS switch
Sorry hit send b4 title creature from black lagoon. When playing game it's week. No resistance if light pressure against it with finger. When I do the test from menu to test flippers, the right 1 (works fine ) power and hold .left one power doesn't move but will move for hold for test.
Quoted from tomthetank:Sorry hit send b4 title creature from black lagoon. When playing game it's week. No resistance if light pressure against it with finger. When I do the test from menu to test flippers, the right 1 (works fine ) power and hold .left one power doesn't move but will move for hold for test.
Check the power at your coil, check solder joints on Fliptronics board and opto board, check for loose wires
It's usually best to keep an issue contained in a single thread. This is so others can follow along and see the details of the issue and what's already been tried/done/suggested.
Original thread: https://pinside.com/pinball/forum/topic/week-flippers-creature-from
This page was printed from https://pinside.com/pinball/forum/topic/flipper-update and we tried optimising it for printing. Some page elements may have been deliberately hidden.
