My 1994 Bally "The Shadow" recently started having issues with the EOS switch on the left flipper. If you hold the flipper button down, the flipper bounces a couple times then falls back down. In short, I'm getting the higher voltage, but not the lower voltage. What is generally the cause of this? It just started doing this. What do i need to do to fix it? Is the switch bad? Is it more in depth than that? Thanks in advance for any help.
