New! Dark mode!
(Topic ID: 237622)
Flipper stutter on Bally Paragon
By Spraynard
1 year ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by dothedoo
    #1 1 year ago
    I finished putting together my project paragon recently, and the left flippers have this weird, intermittent "stutter" behavior. It happens every 7-8 flips or so. Basically, the flipper starts its stroke then sort of stops and finishes it's stroke. (see link to video). New EOS, transfer, and cabinet switches. I tried running some sandpaper through all to make sure good conductivity (for some reason new switches have some sort of coating on them sometimes). I tried replacing the coil. All switches are properly gapped.
    I'm at a loss. What should I try next?
    https://www.dropbox.com/s/hdg5bo8cd0a2loi/IMG_0992.mov?dl=0
    #2 1 year ago
    I hope you are not running sandpaper through the playfield switches. Those are gold plated and should be cleaned with paper like a business card.
    Possible the eos is not adjusted properly and is opening too soon. The EOS should open at about 80% of the stroke. The EOS should also open before the upper flipper activation switch closes. (Break Make). Check the EOS adjustment by pushing in the flipper link with your finger and not by turning the flipper itself.
    #3 1 year ago
    Quoted from BigAl56:
    All the switches involved with the flipper (eos and cab) are high voltage, not gold plated
    #4 1 year ago
    I'm not downloading anything to be able to watch the video...
    #5 1 year ago
    Quoted from cody_chunn:
    You should be able to just stream it on Dropbox, you don’t need to download it
    #6 1 year ago
    I’ll check the break/make timing, thanks!
    You are correct DO NOT file or sand gold plated switches. These are not gold plated switches though.
    #7 1 year ago
    EOS gap and break timing is where I start on issues like this. I've also had it happen with coils that had partial shorts in them. If you lift the playfield and watch what happens while you are replicating the issue that can help pinpoint the issue.
    #8 1 year ago
    Could try just disconnecting the secondary 'make' switch that powers the upper flipper to see if the lower playfield stops having issues
    #9 1 year ago
    alright, so it was indeed the EOS/Transfer timing. The EOS was opening then there was a small delay before the transfer switch would engage. I adjusted so the EOS breaks and Transfer switch makes at about the same time. No more flipper stutter. Still don't understand why the problem was intermittent before, but I'm glad it's now resolved. Thanks for the help pinside!
    #10 1 year ago
    Glad you have it. The important thing to remember here is to always adjust flipper switches by pressing the link in and not turning the flipper.
    While flipper switch contacts are high voltage and can be cleaned aggressively such as filing them, low voltage switch matrix switches are gold plated and should be cleaned only with paper. A business card or, as we old timers used to do, sliding a dollar bill through them.
    #11 1 year ago
    I second this. If there's any wear in the bakelite flipper link there's a chance the EOS switch will not open at all if it's gapped tight and you adjusted it by turning the flipper. And we all know what happens when the EOS switch doesn't open and you trap a ball.
    $ 29.95
    $ 369.00
    $ 145.00
    The MOD Couple
    $ 69.99
    Filament Printing
    $ 48.00
    $ 625.00
    $ 45.50
    The MOD Couple
    $ 12.00
    $ 63.29
    Pinball-Mods.com
    $ 28.00
    Pin Monk
    $ 122.00
    $ 29.50
    $ 5.00
    Docent Electronics
    $ 299.99
    $ 139.00
    Sparky Pinball
    Gulf Coast Pinball, LLC
    $ 59.95
    pinballmod
    $ 11.95
    $ 26.95
    $ 64.99
    $ 139.00
    $ 119.00
    The MOD Couple
    $ 85.99
    € 59.80
    Lighting - Backbox
    Freddys Pinball Paradise
    $ 76.95
