(Topic ID: 299189)
Flipper spacing and how fun a game is, closer = higher rated?
By JohnTTwo
54 days ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 52 days ago by JohnTTwo
#1 54 days ago
Has anyone charted the gap between flippers on games? I find it very interesting that my JP games flippers are so close together compared to other games, and how new people enjoy this game, they love MM and JP I believe these 2 games have the closest flippers and not so many balls go down the middle.
I have put carrot flippers in my No Fear game and man what a change, more people are playing and liking this game, myself included. People on this site mentioned it may change the game flow and dynamics, it sure has for the better. Maybe it makes the tube shot to easy. Lots of control with the longer flippers.
Anyone else notice this of have some thoughts on it?
Have you made a game better by putting on longer flippers? If so what game?
#2 53 days ago
I always thought it would be a fun to run a statistical analysis using flipper gap as the independent variable and things like pinside ratings, average earnings, average ball time, etc as dependent variables, but precise flipper gaps for a lot of machines were surprisingly hard to find. Put 5 people in front of the same machine and ask to measure the actual gap and you get 5 different answers depending on how they line up their ruler. Extend that out to multiple copies of the same machine with different rubbers and variance in flipper angles and it gets even muddier.
1/16th of an inch really does make a difference but its not easy to eyeball. Some games have clearly larger gaps then others, but individual and community perception of the gaps on different machines changes depending on how that table plays. Given 2 machines with identical gaps, one that tends to STDM is going to be perceived wider even if the cause is poorly designed returns on successful shots or punishing rebounds on failed ones.
Whatever a player's skill level and wherever they are on the nudging spectrum from "pinball is a rodeo" to "all movement is cheating" nobody likes it when a ball drains SDTM. Casual players will move on to something else and even skilled ones would rather play something where they can push the limits of risk/reward rather than play defense against the machine avoiding sucker shots and shooting the same loop over and over, save whatever notoriously punishing machines they mastered to pick at tournaments.
Shrinking the gap and/or installing a center post are easy fixes. Good shot/return angles make for a better game for players who put in the time to learn the rules and shots but leaves a lot less tolerance for machines that aren't perfectly dialed in and still results in more casual players getting turned off before they learn enough about the table/rules to get hooked.
#3 52 days ago
Interesting. Might want to consider adding in games that have zipper flippers (potential zero gap), up/down posts between the flippers or static bumper posts between the flippers.
#4 52 days ago
Quoted from craif:
I think the only way to really measure flipper gap is to see how close they get at the closed point in their swing. I pull both flippers up by hand put a ball between them and see what the remain gap is. It is kind of shocking to see how close some are and far apart others are. Thus the correlation between higher rated games and lower rated games. JJP seems to get this and have some very fun games.
